MiniDSP H-Frame.
MiniDSP H-Frame.
Old 11th February 2013, 09:42 PM   #11
john k... is offline john k...  United States
john k...'s Avatar
Originally Posted by gainphile View Post
Interesting. I've never actually tried a higher order highpass for the subwoofer. Always equalised with target response of 20hz, Q=0.5 which sounds great but can be SPL-limited with certain recording/movies.
So this morning I tried to have 24db/oct highpass at 20hz for the sub. To do this by following the prescription: linkwitzlab.com/filters.htm#2
- First, I equalise the woofer for F=20hz, Q=0.707 using Linkwitz Transform
- Then add another biquad for Highpass filter, F=20hz, Q=0.707
Having it for a few moments before going to work, I heard nothing wrong with this. Perhaps group delay is not that audible. I will observe further and it it's good then more SPL can be obtained !!
Try playing vinyl on a dipole woofer system with 2nd order alignment.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 11th February 2013, 10:46 PM   #12
holdent is offline holdent  Canada
John K.. you wrote "Then couple with an LR4 low pass to the midrange". Martin King utilizes a LR2 filter to flatten the rising response of the H-(or U-) frame. Do you prefer the LR4 for a particular reason?
Since I haven't understood most of the discussion can you suggest a good primer for a noob on digital crossovers?
Thanks in advance!
Old 12th February 2013, 01:42 AM   #13
gainphile is offline gainphile  Australia
gainphile's Avatar
I do not have Vinyl system, but I have a lot of Vinly rips, and I know what you mean
http://gainphile.blogspot.com
Old 12th February 2013, 10:10 PM   #14
ttan98 is offline ttan98  Australia
FWIW: Gradient woofer equalization
I don't particularly care for targeting a 2nd order high pass response for a dipole woofer as it means excursion will keep increasing below the cut off point. 3rd or 4th order limits excursion below cut of, but does increase group delay. However, when you look at the GD it is apparent that the major contribution to the woofer GD above 60 Hz low pass filter between woofer and mains.Most recently I have determined that the easiest way to obtain a 4th order high pass alignment is with a single stage Q boost and a single stage Q cut. For the woofer you are using and a 35 Hz cut off, a boost with Fc = 37 Hz, Q = 0.75 and Gain = 14dB, and a cut with Fc = 325 Hz, Q = 0.45 and gain = -12.5 dB should get you close. Then couple with an LR4 low pass to the midrange. [note: the Q's specified are the analog Q's and are not exactly the same at what miniDSP uses. You will need to fine tune.]
John,
Pardon my ignorance why do you need the cut at 325 Hz, Q=0.45 and gain=-12.5db? What happen if the OB between the woofer and mid-woofer is crossed around 300Hz?
I having some difficulty in crossing my woofer and mid woofer accurately(currently around 300Hz) and also boosting around 35-40Hz and how to go about it. I am using the Behringer DCX2496. FYI my woofers(twin) is mounted in a U-frame.
An explanation would help and some guidelines to better interface the woofer to mid woofer, any inputs from anyone is encouraged. Thanks.
Old 12th February 2013, 10:22 PM   #15
CharlieLaub is offline CharlieLaub  United States
MiniDSP H-Frame.
The MiniDSP does not have a very high max output level. You can easily cause internal clipping when using boosting functions like the Linkwitz Transform or other EQ. One way to avoid this is to use the Active Crossover Designer to create advanced biquad coefficients for your speaker. In the stage the will be boosting the level you simultaneously specify gain reduction equal to the maximum boost, essentially creating an analogous "cut" filter. This will prevent internal clipping, however you will need to make up the lost gain elsewhere, e.g. at the amplifier or with an external analog gain stage.
Get ACD here:
the Active Crossover Designer web page
-Charlie
Old 12th February 2013, 10:51 PM   #16
john k...'s Avatar
Originally Posted by ttan98 View Post
John,
The eq I suggested is correct for the XLS woofer in a 18" H frame. It should be close for H frames within a couple of inches either way. The two stages serve to shape the response to a 35 Hz cut off, correct for the dipole roll off and bring the sensitivity to that of the woofer operating as a monopole in 2Pi space (the manufactures specified sensitivity) at the dipole = monopole frequency. This is simpler that using a couple 1st order shelving filters and a Q boost to raise the system Q to other than 0.5 and then attenuating to correct the sensitivity.
I would expect in your case you would have trouble if the U-frame is also on the order of 18" as the on axis response peak (cardioid peak) would be at about 185 Hz. If the U-frame is correctly damped and on that order in length, it is only suitable for use to about 125Hz.
My recommendation has always been to low pass the woofer at least 1/2 octave below the "dipole peak" frequency and to place the low frequency cut off so that there is no more that 20dB gain max at the cut off frequency. If you look at an 18" dipole the dipole = monopole frequency is about 125 Hz. 35 Hz is about 2 octaves below that requiring 12dB gain at 35 Hz for the dipole roll off and some additional to bring the driver Q to the desired level netting the +14dB. The cut at higher frequency is close to the dipole peak frequency (376 Hz ideally) and the cut is to compensate for the continued rise above the dipole = monopole frequency to the dipole peak. -12 db turned out to be what was required. The Q of each stage was what was required to make the response basically "flat" above the woofer cut off. Then the LP filter is for the crossover to the midrange.
Old 13th February 2013, 03:29 AM   #17
sfdoddsy is offline sfdoddsy  New Zealand
So that's about four recommendations of how to EQ an H baffle so far. All different.
No wonder people choose to buy commercial.
Old 13th February 2013, 03:38 AM   #18
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
My POV but it's not active...
Place a big bobbin before the woofer!
And attenuate a lot the upper ways
Old 13th February 2013, 10:05 AM   #19
That's five. Maybe six.
But seriously, I would have thought EQing an H-Frame sub is one of the easier DIY dipole tasks, especially compared to EQing the midrange which is still bugging me after ten years.
If the H-frame is the same width and depth as the Orions, with the same driver, it should require the same EQ.
As for a high pass, I've spent more time than I will ever get back trying and measuring different high passes. Some to a monopole sub below 40Hz. Some at 20Hz or so to protect the drivers. There is certainly a measurable increase in Group Delay with some, but I would be lying if I said it was audible once you correct for phase and response.
Just last night I wasted time checking the difference between my prepros 12db and 24 db sub crossover. Big difference at first. Until I remembered to flip phase.
Old 13th February 2013, 10:44 AM   #20
john k...'s Avatar
And how many ways are there to design a "box" woofer?
MiniDSP H-Frame.Hide this!Advertise here!
Basic miniDSP volume control question for a miniDSP n00b architect7 miniDSP 8 26th January 2012 01:40 PM
H frame vs W frame dipole woofers rick57 Multi-Way 18 8th October 2011 04:58 PM
miniDSP 2x4, a new home for miniDSP minidsp miniDSP 8 27th August 2010 01:11 AM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 04:44 PM
H frame/ Dipole/U frame ???????? j.burtt Multi-Way 24 1st May 2006 03:50 AM
Copyright ©1999-2017 diyAudio
