Help with first order series crossover?
Old 10th February 2013, 11:57 AM   #11
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
My current system is with series 1st order!
It uses an old Altec woofer ----very very good
and a novel 2" mounted in a 6" waveguide for mid-tweeter duty.
L is about 2 mH and C is 12 uF
Edit: the old and famous DQ10 speakers incorporated a series crossover
Old 10th February 2013, 12:25 PM   #12
vacuphile is online now vacuphile  Netherlands
vacuphile's Avatar
Majerjack, I think Wolf_teeth's remarks on a resistor paralled with the tweeter are right on the money. Sometimes it is the most economical solution.
One word of caution on the use of of a parallel 1st order passive xover: without drivers mounted, it will create a dead short at the xover frequency. It can kill your amp.
As to 1st order in general, as has been remarked before, it only works with carefully selected drivers with flawless operation up to at least 2 octaves outside the xover point. And even if you would find such drivers, it will be very difficult to find a solution to compensate for the increasing beaming of the low driver, this in combination with the profound lobes you create with low order filters. This will necessitate you to work with small drivers, closely spaced with a low xover frequency, 2KHz or so. This also shows the impractability of a 1st order setup; you would need a tweeter that still does its work well at 500 Hz (2 octaves below 2KHz)
But from now on I will be discrete about it.
Old 10th February 2013, 12:26 PM   #13
tvrgeek is offline tvrgeek  United States
Gee, and I thought it was the $1 piezo tweeter that made me hate them so much!
Old 10th February 2013, 12:31 PM   #14
vacuphile,
Or three and four way. See Vanderstein 2Ce. My next project is a 6.5 inch three way. Just finding a mid I can cross at 5K first order has been a killer. I will use the identical Seas woofer and tweeter from my last build, (LR4 acoustic @ 2.6K )
Old 10th February 2013, 12:58 PM   #15
speakerdoctor is offline speakerdoctor  United States
Here's a pretty good thread link. However, the Acoustic Reality XO site is gone. They had some great instructions on how to empirically select the xover components.
"It's all about the music!"
Old 10th February 2013, 01:08 PM   #16
vacuphile's Avatar
Tvrgeek, that looks like an interesting project, but if I may make some suggestions: before you make a passive filter, first do some measurements and listening tests with an active setup using something like a MiniDSP. This will show you which filter slopes and xover frequencies will work best. Don't just measure on axis, but also look at what happens off the horizontal and vertical axis. 5K from mid to tweeter is in my experience way too high, as you will note from such tests.
A very nice little speaker that would match up good with your other components is the Fountek FR88EX they have at Madisound. It is advertised as fullrange, which it is. It does have some breakup above 10KHz and ultrasonic it goes nuts, but it is a very good midrange.
Old 10th February 2013, 02:02 PM   #17
Ooops! sorry for forgetting to paste the link prior. Here it is...
Series Crossover
The link below is to a much larger thread that basically debates the merits of series xo's. Some heavy hitters participated in this one. You should pay attention to what they wrote. Particularly JohnK....
http://www.diyaudio.com/forums/multi...eries-xos.html
Old 10th February 2013, 02:12 PM   #18
R.I.P.
Originally Posted by wolf_teeth View Post
I'm sorry, but this is wrong.
Wolf
Bizarre then that you follow with an example that shows
exactly what I said, series+parallel is used in that case.
You are wrong. A parallel resistor on its own will not
attenuate a tweeter, only change the x/o point and Q.
Can help with tweeter impedance peaks sometimes.
rgds, sreten.
Old 10th February 2013, 02:24 PM   #19
vacuphile's Avatar
Agree with Sreten, had overlooked this when giving blanket support to Wolf_teeth
Old 10th February 2013, 02:27 PM   #20
system7 is online now system7  United Kingdom
system7's Avatar
Squabbling as usual...
Back on topic. The Acoustic Reality XO from my archive, since it getting hard to find:
I expect it would work best with a good flat polycone.
The gurus tend to do something more complicated. This is a Troels Gravesen design IIRC:
Tony Gee did this one at Humble Homemade Hifi:
Tricky things.
Best Regards from Steve in Portsmouth, UK.
Help with first order series crossover?Hide this!Advertise here!
LR 4th order vs LR 8th order crossover redliner Subwoofers 1 7th January 2009 11:32 PM
6th order series tuned aznboi3644 Subwoofers 2 3rd September 2008 03:36 AM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
Series or parrellel 3rd order? Westrock2000 Multi-Way 7 11th December 2002 10:22 AM
2nd order series XO navin Multi-Way 3 24th October 2002 05:15 PM
Copyright ©1999-2017 diyAudio
