Old 12th February 2002, 02:05 PM   #11
SteveG is offline SteveG  United States
Account Disabled
Oops... forgot the website-
http://www.tb-speaker.com/
click on tweeters and scroll down to full range section. check this out:
Old 12th February 2002, 02:28 PM   #12
Thanks guys this is EXACTLY what I was looking for.
I see you pointed to the W3-319 would this be the model you would recommend? (Looks like any one of them will do).
Being that they are serving as near-field surrounds I'm thinking of running a little pot in-between (to dial down the volume), I know very little about EE, can I just slap a pot in the line of speaker wire? Is there certain specs of the pot I should look for?
And wilst I have your attention, any recommendations on a little sub amp (25-50W) I'm looking at the 25/25 Watt on apexjr.com .
Old 12th February 2002, 04:21 PM   #13
Account Disabled
Well, not having heard any of them, I can't really recommend which one is better. The model I posted was the one I was looking into for a budget surround setup. As far as attenuation goes, you need an L-pad in line with the speaker. It's basically a high-powered potentiometer set up to keep the impedance (ohms) seen by the amp at the same level while attenuating the driver. You should be able to find them about anywhere. Don't know about the sub amp. I know that you can get 75 watters for pretty darn cheap these days. Look at www.partsexpress.com
Steve
Old 12th February 2002, 04:51 PM   #14
Okay an L-pad, any idea of what watt I should look for? The surrounds will probably be "doubled up" on the amps taps, so I have the headrest and outside surrounds going (for riends). Do you think a 50W L-pad would be apropriate? Are there special considerations on the "doubling up", I figure it will be negligable.
also any idea why the l'pads have a pair of three leads instead of two? (maybe a ground?)
Thanks again for the advice it is proving most usefull.
Old 12th February 2002, 05:05 PM   #15
Account Disabled
check out this link for L-pad wiring:
http://colomar.com/Shavano/lpad.html
Old 12th February 2002, 10:12 PM   #16
you are the man.
Old 15th February 2002, 07:50 AM   #17
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
why not use analog attenuation before your power amplifier? I don't know what kind of setup you have, but a stereo pot to attenuate your line level signals is probably a better way to go.
- Chad.
Old 15th February 2002, 03:24 PM   #18
Thanks for the suggestion
The chair is designed to be able to easily integrate into most HT setups, the headrest surrounds are in addition to existing ones so they require their own volume control, not the audiophile option, but I think an L-pad makes the most sense.
Hey SteveG, where are the TB's for $4? Under 3" drivers I see them for $7, I'm assuming that the MCM brand 3" wideranges are just OEM's of TB's right?
Old 15th February 2002, 04:21 PM   #19
Account Disabled
Well, I thought that MCM was selling them for that. Maybe they raised the price back up when they realized that they would sell A LOT of them! Yes, the MCM brand are relabled TB's. If you look closely at the picture on their site, you can see the TB label. Sorry to give misinformation on the price! I thought they were down around $4.
Old 15th February 2002, 05:08 PM   #20
Thats pretty much what I figured, still cheap though at $6 quantity.
Wide range driver questions for xo.. JandG Multi-Way 2 23rd October 2006 12:11 AM
New Reference Speakers with Full/Wide-Range Driver surf,sun&sound Full Range 206 15th June 2006 12:27 PM
Wide range driver based 2 way system, Supravox?? zygibajt Full Range 18 14th March 2006 01:42 AM
help me choose a wide range driver johnmark Full Range 38 26th June 2005 08:39 AM
wide'ish range driver? dunderchief Multi-Way 1 17th July 2004 11:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
