Where's the best place to get a capacitor?
Old 8th February 2013, 06:52 PM   #11
alan-1-b is offline alan-1-b  United Kingdom
Default not non-polar electrolytic cap
If your loudspeakers are of quality and you hope to use them for a long time ,
then I advise you do not buy electrolytic caps for repairs , because they will deteriorate ... as you can see the one you have has.
Buy polypropylene , and a low voltage one will suffice.
You will not need one of the 400 volt rated capacitors to replace a tweeter capacitor.
If the sound is slightly too bright with the new poly cap , then connect a 1 ohm 5 watt resistor in Series with the capacitor.
Electrolytic caps , such as your old cap seems to be , have internal resistance ,
and polypropylene caps do not ,
but listen first , because you may prefer the sound with no added resistance.
You can fine-tune the treble output with slightly more or less resistance.
If the original sound had OK treble balance , I doubt you will need more than 1 ohm added , but you may prefer a little less added , try 0.47 ohm next.
This will have to be decided by listening.
I advise you buy a new 6.8uF cap for the other speaker and install now also.
You will then have same treble quality from both speakers ,
{ and the other old cap will fail eventually }.
Alan
Where's the best place to get a capacitor?Hide this!Advertise here!
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 20 27th July 2016 08:11 AM
mkt capacitor vs mylar capacitor Vrystaat Solid State 4 5th July 2016 05:15 PM
Where is this place? Qub The Lounge 18 18th October 2007 03:03 AM
Am I in the right place? chrispenycate Introductions 8 11th September 2006 11:36 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 10:26 AM
Copyright ©1999-2017 diyAudio
