#21 |
@ Earl, I'll take this to the other thread.
The room can not see the difference. Yes, view them as energising the room as a sub might. You'll be limited by their placement options. A separate sub (at least) would be a good move IMO. The powerpoint presentation would make a good read if you haven't already. |
#22 |
EQ still would be better than doing nothing.
Markus |
#23 | |
Markus |
#24 |
The best locations for subs is not necessarily where the mains are. Mains should be placed for best imaging, subs should be placed for lowest point-to-point differences within the listening area. Best case they also act as active absorbers, reducing modal ringing.
Markus |
#25 | |
That's some nifty software you got there. Did you also look at how modal decay is affected by the process?
Markus |
#26 |
#27 |
Thanks - no I did not look at the modal decay, but I suspect that it being a minimum phase system, as the frequency response is made smoother the modal decay will follow suite.
#28 |
John Mulcahy (author of REW) has shown that this is not always the case: Minimum Phase
Markus |
#29 |
If you want the best solution IT IS BASS TRAPS.. Most people are simply using inferior commercialy driven products that arent very effective or do nothing at all..(ie)light weight foam wedges.. EQ is a good tool to show improvement for the problem but bass traps will sound better by reataining your systems characteristics..
The challenge is you need many bass traps including ones with High Density Insulation(2lb per cubic foot) and 1/8" and 1/4" thick panel traps.. I'm planning a room for a friend based on this were the traps are built into the new framed wall and ceilng with alternating insulatiuon trap and panel trap.. In an existing room you might need 20 or 30 large 4" thick traps plus some panel traps and this is were the problem is as most will get a few and wonder why there isnt a big improvement and give up.. the waves are large and need to absorb going in and absorb refected wave coming out.. Then there's the cosmetics but making then yourself will help..Mine are diy wood frame and fabric covered.. Picture shows 4 traps spaced apart from each other behind the speaker and attached to back wall is a wood panel trap to reduce even more energy that otherwise will come off wall strong..Room has 20 plus bulk heads and Absorbers hidden in ceiling behind fabric.. My room was measured with ETF and Cal Mic and watched and listened to the response smooth out and the ringing stop and now listen to recordings a better way.. Audio Keen People that listen in my room find it a complete JOY with the Focused soundstage and spatial information and balanced bass.. When turned up It's loud in the soundstage and not loud in the room if you know what I mean.. Off Topic some what but If you were to consider this than the rooms diffused energy will have to be considered and theres 2 camps on this.. Some want some or a lot and others want none or very little.. most recordings already have ambient information built in, fake, or real and this built in information revealed more in a more dead configuration.. If you follow Ethan Winer on other forums, he has a deep understanding of this topic and helpful.. I read his comments with passion but watch some get scared away as he also sells treatments so could be taken as a sales pitch if he says you need more bass traps by I chuckle inside becasue I know he"s being honest and it's driven by passion.. Cheers, Joel |
#30 |
That there could be frequencies that the system is not MP is possible. That these are a dominate issue at LF is improbable. Hence "in general" flattening the response minimizes the decay.
| Simulating bass response with duct and speaker position | ashok | Multi-Way | 15 | 17th August 2012 10:37 PM |
| Calling BudP - enabl vs room modes | just a guy | Full Range | 14 | 26th August 2009 11:57 AM |
| Planar bass wave to take care of room modes ?? | JinMTVT | Subwoofers | 12 | 4th October 2007 05:15 PM |
| DBA (dual bass arrays) and active bass traps | capslock | Subwoofers | 3 | 20th August 2006 12:52 PM |
