SIMPLE QUESTION: Can a 10" woofer give me the same bass of a 15" one? - Page 7 - diyAudio
Old 8th February 2013, 03:07 AM   #61
terry j is offline terry j  Australia
ah, maybe you're right?
If you are then it would be easy to see someone decide 'no need for bigger in terms of better sound'.
Old 8th February 2013, 03:10 AM   #62
I think that a good 15 inch with low qts an fs will never loose to a 10 inch.
Old 8th February 2013, 04:08 AM   #63
"same bass"
No one seems to be talking about sonic charateristics . I will take many smaller woofers over larger ones(but not all) for the pitch definition and speed but I have heard larger ones that sounded organic without congestion or one note sound(ie)Edgarhorn seismic subwoofer with 18" woofer
Old 8th February 2013, 07:14 AM   #64
Originally Posted by Joel Wesseling View Post
"same bass"
I most certainly was talking about sound! See a few posts above.
Now THAT is an interesting curve ball you have introduced.
Old 8th February 2013, 01:28 PM   #65
Sorry, you're right!
I think my post could be misread.. Edgarhorn Seismic Sub Characterists, I feel are really attractive. Lots of definition, go very Low, exremely high sensitivity, Huge in the room bass presence but more toward warm sound..But, I couldnt imagine how to integrate with a apeaker for 2 channel music..
Thinking about Sub for descrete 5.1, the sub with NHT XD would work very well for me.. Smallish cabinet and woofers that had large and effortless sonic impact that filled the room..
Now I wish I could diy a sub like NHT with associated digital electronics to make it work all for a low price.
Old 8th February 2013, 01:37 PM   #66
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Hi Terry,
Ask your self does every 10"the same? Or every 18".
If the answer is "no" why do they sound different.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 8th February 2013, 02:23 PM   #67
Originally Posted by murillollirum View Post
hi Rui, excellent response for a 10 inch, the problem is the low 84.6dB... there is always a problem.
Maybe I was going on about sonics but your original post was simply asking about Low Frequency Bass reproduction..
"problem is the low 84.6dB... there is always a problem."
Are you saying you have a in room problem somewhere in the bass region?
My room had a big peak at 90hz and smaller peak at 45hz plus a huge 12db cancellation in between that sucked the life out of Large amplifiers as try to raise volume to feel bass is balanced with no possible way of getting there..
Room is all fixed now with room treatments and my power amps have gotten smaller(6-15w) and have balance and lots of volume..
Cheers, Joel
Old 8th February 2013, 02:44 PM   #68
Cheers, Joel
yes Joel, I discovered that the problem is caused by room modes, I also opeed another thread asking how to solve room modes problems. Thx for your help.
Old 8th February 2013, 05:06 PM   #69
No Problem..It's all about mutual passion..
I had to post there as I'm huge believer in room treatments
Old 9th February 2013, 12:25 AM   #70
Speedysteve7's Avatar
Hmmm - For high SPL, deep bass 20Hz upto 100Hz try a pair of tapped horns.
What's not to like... 15" for me - everytime.
12" would go pretty low though to be fair. 18" would be sub hearing but need a 9' tall enclosure and not reach up to the rest of the system freq wise - common sense prevailed.
15" in throat
The horn
One ready
Bass should be fast and tight, deep and LOUD when when playing thunder! These pressurize a room - even a very big room to give you reasonable church organ playback
experience.
I had folk at Scalford show requesting I play Tocata (D minor), once word had gone around how they sounded in the big room - hehe.
Efficiency 105dB/w. Max cone excursion at at 0.9mm at 30Hz (modelled in Hornresp)
Play nice and flat to 20Hz measured.
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 01:43 PM
Rock and Roll speakers, is a Chebyshev bass XO going to give more "Kick"?? Moondog55 Multi-Way 11 18th July 2012 06:34 AM
FS: 15" woofer from Ross B1550 bass amp Jimmy154 Swap Meet 1 26th March 2007 06:38 AM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 03:29 AM
Copyright 1999-2017 diyAudio
