SIMPLE QUESTION: Can a 10" woofer give me the same bass of a 15" one?
Old 3rd February 2013, 09:16 AM   #31
balerit is offline balerit  South Africa
balerit's Avatar
Originally Posted by JMFahey View Post
Back to the speaker choice, *if* you are limited by size (as in designing a speaker system for a typical Living Room) a 10" speaker can easily outperform a 15" speaker, hands down.
I'll take you up on that, try beat these, they'll blow your back wall out if they're not brick and mortar
Old 3rd February 2013, 01:55 PM   #32
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
EDIT: I was answering to tinnitus
ok, lets take a normal 88db 10" bass/sub woofer
post.
Agree and add:
put in in a closed box where it rolls off at 35hz, giving -6db at 30hz
then put a 96db 15" in a closed box where it rolls off at 50hz, giving -12db at 40hz
Well, that's cheating, because the box which will allow the 15" speaker do so, will be, say, 20X the volume of the other one, so, the example is not valid.
so if you remove anything above 50hz, SPL at low frequencies could be equal for both woofers, in theory
will it happen that way in reality ? .......don't know
Well, I know, because I have tested *many* speaker/cabinet combinations; I commercially make Bass amps and cabinets so for me it's a very real problem to solve.
Back to the question: "if you remove" ... (you'd need a steep and expensive crossover for that) they may *measure* the same SPL with a sinewave, but won't sound the same with any program you send there.
Basically the 15" in a too small cabinet will sound "dry" while the 10" in a cabinet where it feels comfortable will sound "smooth".
Hope the words explain the sound.
but man, when I look at a hifi woofer, and visually compare it to a PRO woofer, many hifi woofers look like crap
That's a personal visual preference, can't argue about that, I often see it the other way.
But anyway "listening with your eyes" is for noobs and the untrained, isn't it?
EDIT: now answering to balerit bragging
Well, if the objective is blowing brick and mortar (which they really aren't capable of doing, of course) yes, I agree they will achieve a higher SPL.
As of the sound, it will be incredibly uneven, with a strong 200Hz bump, no real deep bass, honking shrill treble and no real high end either.
Typical "horn sound".
Mind you, I respect Altec Lansing A7, have built a ton of them (long ago), and they were state of the art ... in 1935 .
I *have* mixed records in Pro Studios which used them as monitors, in the late 60's.
By '75 nobody used them any more.
Maybe there was some reason for that
Since you seem to be a Horn man (fine with me) I suggest you add some good bullet tweeters to hear something above 10 KHz, and a couple man sized Bass horns (starting about 8X the cabinet volume you have now) to have something below 100 Hz.
Personally I'll keep my Hi Fi type all-cone speaker (ok, it includes a silk dome tweeter).
Altec Lansing A7 were needed when you had to fill a 1600 seat Cinema Theater with a 30W tube amplifier; nowadays SS watts are cheap and plentiful.
PS: congratulations, beautiful cabinet work.
Old 3rd February 2013, 02:14 PM   #33
a.wayne is offline a.wayne  United States
Sin Bin
Lol, or blow out your backwall if it's made from tar and paper ....
Old 3rd February 2013, 02:16 PM   #34
murillollirum is offline murillollirum  Brazil
Ugh !! Like covering a steak with crushed Oreos and sprinkling vanilla over it.
Marinate your lamb overnight in *dry red* wine and spices before cooking and *then* maybe we'll agree.
As in way flatter response, deeper bass, smooth sound, and so on.
It will need more driving power, of course, piece of cake.
Now, if we talk live sound, such as Band PA or DJ stuff , and have no size/weight/power limitations and want highest SPL, yes, 15" are preferred over 10".
But to make a choice, the OP question must be rephrased in more precise terms.
As is, it's too vague.
Dear Hermano, if you someday come to Fortaleza, Brasil, I will go with you to show you how delicious is this lamb It a young lamb, here we call `cordeiro mamão` so the meat is very soft.
By the way, I love Buenos Aires, there I eaten the best Bife Chorizo in my holy life at "El Cabrera"!!! I pretend to go back when there is a good musical show, like U2 or other rock band, if you should know some concert please let me know.
Gracias.
Old 3rd February 2013, 03:08 PM   #35
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
post.
Agree and add:
isn't that a bit over the top ? ...2x volume would do it, and be quite fair I would say
Back to the question: "if you remove" ... (you'd need a steep and expensive crossover for that).....
one more .... I will have to choose my words more carefully in the future ...I would never use higher than 24db for a sub filter
I hope this don't mean you take me for an idiot ....
no, I really think quality hifi drivers are overpriced
and technology is...just average, mostly
Old 3rd February 2013, 03:27 PM   #36
multisync is offline multisync  Canada
Balerit,
I love em too.
I have a pair of A7-500, 416's and 511's That I bought back in 1970 and they are waiting for a new cabinet. I have a picture of the originals somewhere.
Old 3rd February 2013, 04:32 PM   #37
Inductor is offline Inductor  Portugal
Inductor's Avatar
Originally Posted by murillollirum View Post
5) so with a quality 15 inch, a good enclosure and a good power, there is no way a 10 inch can beat.
Try to beat this 10" and don't ask silly questions. (And) Prove it!
Note: this in someway relates to "what's the best loudspeaker driver" question that many ask... good question, there's always a better one/application.
Old 3rd February 2013, 04:39 PM   #38
JMFahey's Avatar
Just do the Math, it will clear many doubts.
Old 3rd February 2013, 04:40 PM   #39
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
try beat these
OK, nice satellites, but why no pictures of the woofers?
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd February 2013, 04:41 PM   #40
JMFahey's Avatar
Gracias.
Thanks, I'll remember your invitation.
Obrigado, vou lembrar seu convite
SIMPLE QUESTION: Can a 10" woofer give me the same bass of a 15" one?Hide this!Advertise here!
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
Rock and Roll speakers, is a Chebyshev bass XO going to give more "Kick"?? Moondog55 Multi-Way 11 18th July 2012 05:34 AM
FS: 15" woofer from Ross B1550 bass amp Jimmy154 Swap Meet 1 26th March 2007 05:38 AM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Copyright ©1999-2017 diyAudio
