SIMPLE QUESTION: Can a 10" woofer give me the same bass of a 15" one?
Old 2nd February 2013, 09:58 PM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
no...unless all other variables than size are fixed
Old 2nd February 2013, 10:48 PM   #22
murillollirum is offline murillollirum  Brazil
ok. thx to all here, now I will order my dinner, a lamb au sweet wine... and see the brazillian guys kick some a.. in UFC 156. Good night to all you guys.
Old 2nd February 2013, 11:14 PM   #23
Cornelis Spronk is offline Cornelis Spronk  United Kingdom
Default Speaker resonance
Speakers do not produce strong sound output below their resonant frequency.
Resonance is the natural frequency of vibration of any mass attached to a spring like restoring force. For any speaker, its lowest resonant frequency is in free air. While in free air, however, the air from the back comes around and cancels the air movement from the front. This is because when the speaker is pushing the air from the front side, it is pulling the air from the back. Even while a speaker in free air may be moving a lots of air, it will not sound very loud. The pulled (low pressure) will cancel the pushed air (high pressure).
The free air resonant frequency depends on the mass of the cone, and the stiffness of parts that support the cone. If you modify the cone support system, you will change its resonance. The stiffer the the support, the higher the resonance. All other things being equal, a speaker with a foam surround will have a lower resonance that a speaker with a rubber surround. This has an advantage for good bass. However, foam breaks down more than rubber with age, and in 20 years you may have to replace the foam.
When a speaker placed in a box, the resonance is increased, because the air behind speaker acts a restoring force which has the same effect as stiffening the surround.
When a large speaker is placed in a small box, it moves more air inside the box than a smaller speaker. This gives the larger speaker the impression that the air in the box is stiffer than what the smaller speaker would experience. The net result is a larger shift in the resonance of the larger speaker, driving the resonance up more.
If a box is too small, the larger speaker is at a disadvantage. Yes, a large speaker will move more air, but not in a box that is so small as to drive its resonance up too much. Net result, its low bass output will suffer more.
Just the facts! State your evidence.
Old 3rd February 2013, 01:53 AM   #24
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by murillollirum View Post
Please be honest, can a 10 inch woofer offer the same impact of bass, I'm telling of the first octave 20-40Hz of a 15 inch?
I;m asking this because of the quote of a JBL guy, MArk Gunder: "to make sound, you must move air"
I hope this is not what you are telling your wife ....
Originally Posted by Cal Weldon View Post
Too vague of a question. It's like asking: can a truck go faster than a sportscar?
Some sportscar to be beaten by a truck ...
Originally Posted by sreten View Post
A really good 10" will slaughter a poor 15", it just needs around double
the xmax to do the job the same. Given your talking 20Hz to 40Hz, that
is possible in moderate volume with a lot of power with a 10". Generally
speaking a poor 15" will need a lot more box volume and less power.
However, if the 15" has about 4 times the cone mass of the 10" and
the same xmax, it will slaughter the 10", but will need a far bigger
magnet to do so, and will be commensurately much more expensive.
A good 15" will kill a good 10", depending on your design criteria.
Which it all boils down to, good design, and proper drivers for purpose.
rgds, sreten.
Agree , SPL ONLY , As Long excursion , means more distortion , when the woofer has to come from waaaaayyyy out there for the next bass note ...
Originally Posted by pdul View Post
What became of the 30" from Fostex. I saw them in the 80s?
Two of those would make a nice sub.
In the 70's i had EV 30inchers and Hartley 24inch monsters , stupidly , I gave them away ...
Old 3rd February 2013, 04:34 AM   #25
balerit is offline balerit  South Africa
balerit's Avatar
Usually, but not always, the sensitivity of the 15 inch is higher than the 10 inch therefor it requires less power from the amplifier. The comparison you are trying to make is like saying a 4 cylinder engine is better than an 8 cylinder engine.
Old 3rd February 2013, 06:04 AM   #26
Originally Posted by balerit View Post
........is like saying a 4 cylinder engine is better than an 8 cylinder engine.
for fishing boats they have preferred 3 cylinders for being less hard on the wood construction
Old 3rd February 2013, 07:43 AM   #27
zobsky is offline zobsky  India
zobsky's Avatar
Too vague a question with more detail on the specific drivers, but just to humor you,....Horn load the 10" and compare it to the 15" It's the 15 that might be trying to justify its existence
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 3rd February 2013, 08:36 AM   #28
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
lamb au sweet wine
Ugh !! Like covering a steak with crushed Oreos and sprinkling vanilla over it.
Marinate your lamb overnight in *dry red* wine and spices before cooking and *then* maybe we'll agree.
Back to the speaker choice, *if* you are limited by size (as in designing a speaker system for a typical Living Room) a 10" speaker can easily outperform a 15" speaker, hands down.
As in way flatter response, deeper bass, smooth sound, and so on.
It will need more driving power, of course, piece of cake.
Now, if we talk live sound, such as Band PA or DJ stuff , and have no size/weight/power limitations and want highest SPL, yes, 15" are preferred over 10".
But to make a choice, the OP question must be rephrased in more precise terms.
As is, it's too vague.
Old 3rd February 2013, 08:57 AM   #29
ok, lets take a normal 88db 10" bass/sub woofer
put in in a closed box where it rolls off at 35hz, giving -6db at 30hz
then put a 96db 15" in a closed box where it rolls off at 50hz, giving -12db at 40hz
so if you remove anything above 50hz, SPL at low frequencies could be equal for both woofers, in theory
will it happen that way in reality ? .......don't know
but man, when I look at a hifi woofer, and visually compare it to a PRO woofer, many hifi woofers look like crap
Old 3rd February 2013, 09:09 AM   #30
lolo is offline lolo  France
lolo's Avatar
it's not that easy, very often the large, very high sensitivity pro woofers have a rather high Fs.
SIMPLE QUESTION: Can a 10" woofer give me the same bass of a 15" one?Hide this!Advertise here!
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
Rock and Roll speakers, is a Chebyshev bass XO going to give more "Kick"?? Moondog55 Multi-Way 11 18th July 2012 05:34 AM
FS: 15" woofer from Ross B1550 bass amp Jimmy154 Swap Meet 1 26th March 2007 05:38 AM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Copyright ©1999-2017 diyAudio
