Just posting a new thread on the Sonusfaber Cremona. I've just have some information conserning the drivers and the filter. The drivers are: Bass: 2 x 180 mm matching ScanSpeak 18W8531 cone drivers. Medium:150 mm ScanSpeak 8530 revelator cone driver. tweeter:29 mm ScanSpeak Ring Radiator D2904/700000. The filter is a first order 6db and the cut frequencies are around 300 and 3khz. If any body news anything about the filter design I'll be glad to know about it. Christopher |
#2 |
Tweeter is not Scan-Speak, Tweeter is Vifa.
#3 |
Thanks for your reply, just some notes from me.
I still think it is the ScanSpeak Ring Radiator D2904/700000 seting in the Cremona. The specifications of the Cremona is in the 3db range up to 40khz, and the tweeter from Vifa does not ofer that...unless I they does not manufacture it for personal use. If you you look at the mounting holes placements you will notice that D2904/700000 have three inner holes aligned with three external holes which is not the case for the tweeter from Vifa.... I've got my info from a retailer here in sweden so I am pretty confidant in the fact that the Cremona is using the Scanspeak element... Christopher |
#4 |
It´s pretty darn obvious it´s a Vifa.
Check out the SS unit on the website and you´ll see. Holes can be drilled you know. |
#5 |
A couple of points:
- Vifa and Scan-Speak are different product lines manufactured by the same company, Danish Sound Technology. - The face plate of the tweeter used in the Cremonas is clearly custom-made; it has a cutout on the bottom and has Sonus Faber etched on the front. - The diaphragm and phase plug look almost exactly like the Vifa model, and not much like the Scan-Speak; even so, the Sonus Faber driver seems to have a brass phase plug not shown on the Vifa: ![]() ![]() Vifa ![]() Scan-Speak And as I mentioned before, Sonus Faber is obviously using a custom job - at least as far as the faceplate goes - and they are all made by the same company anyway. So this is a rather silly argument IMHO.
#6 |
The Cremona use the Vifa tweeter, end of story.
The speakers have been in production long before the scan-speak 7000 was developed. |
#7 |
wow that is one bad-*** speaker. that's the first time to see a speaker using two 7 inch revelator mid/woofers. nice.
#8 |
Sonus Faber Cremona uses a modified ScanSpeak Ring Radiator D2904/700000.
#9 |
Cremona uses VIFA tweeter.
SS 700K is used in higher level models. |
#10 |
on my Cremona "replica", i use the SS 70000. Sound is great !!!! It's my first DIY job and i wanted to build something "special"... ![]() For now, it's not a cremona like casing but it seems like a crate with drivers on it !!!! I will start to build the real casings just after : i couldn't wait to hear this sound......
| Sonus Faber Cremona Clone | audioPT | Multi-Way | 31 | 27th May 2010 04:26 PM |
| sonus faber cremona : clone / active | soundengine355 | Multi-Way | 5 | 23rd August 2009 01:21 PM |
| sonus faber cremona xt25 speculation | george a | Multi-Way | 12 | 21st April 2005 02:04 AM |
| Sonus Cremona clones | Great Dane | Multi-Way | 7 | 13th November 2003 08:52 PM |
