First Timer Loudspeaker Constructor - Page 2 - diyAudio
Old 30th January 2013, 10:07 AM   #11
tvrgeek is offline tvrgeek  United States
And reality never seems to quite match the models. I use WinISL. Still, I prototype. Measure the response, measure the impedance curve and Q. Then you will learn tricks.
If building a speaker to not use a sub, then a dB or too hump before roll-off helps with the illusion of deeper base and balances the top. If you are using subs, sometimes you use the hump and shift the sub crossover down. If you use a full electronic 2-way sub crossover, then you may go to a smaller sealed cabinet. Most OEM speakers are aligned in a smaller than "perfect" cabinet. Monkey coffins just don't have the WAF. C4 is a popular alignment. Just a tad of ripple, but lower cutoff.
The one most overriding design constraint of speaker design: It depends.
Oh yea, no reason to tune an 8 inch to 22 Hz. It can't push that much air without coming apart or high distortion. You should expect an honest 40 to 45 Hz. That covers everything but a tiny portion of some music or movie effects. Only a pair of 12 inch subs should be expected to do that. 6 inchers are good in the 55 to 60 range. etc. Just because the model draws a line on a graph, does not mean it is a good idea.
Old 30th January 2013, 10:47 AM   #12
just another
wintermute's Avatar
when modeling if possible also look at the transient (or step) response. The lowest 3db point will usually also have the worst transient response....
everything is a tradeoff. maximizing bass extension is always at the expense of something else
Tony.
Any intelligence I may appear to have is purely artificial!
planet10 needs your help: Let's help Ruth and Dave
FREE: Old issues of Wireless World, Practical Wireless and Radio Constructor dij Swap Meet 18 14th February 2015 11:05 PM
Simple Killer Amp Constructor Thread macka Solid State 537 6th September 2011 05:01 PM
Is Mark Levinson a constructor? reinhard Solid State 8 21st November 2006 03:22 PM
Copyright ©1999-2017 diyAudio
