#21 | |
I have a set of 2402J magnets (annular ring horn tweeters) which are almost completely demagnetized. I have a pair of much older 075s with the original magnets which are fine. I prefer the alnico 075 to my later ferrite 2402s, but that may have something to do with the diaphragm vintage (all are OEM JBL) Mids are 2440 again alnico and the magnets are fine (I was told they had been remagged before I got them.) I've also had 2420s, 2405, D130/D140 all alnico.. The biggest issue with these drivers is that most aftermarket replacement diaphragms are not very good quality, and I've found I much prefer aluminum to titanium, and OEM to anything else I can afford.. Other aspects IMO of the driver design whether woofer, or horn driver probably play a bigger role in performance than the type of magnets used. Incidentally there are analogs in the pro line for most if not all of the early alnico home drivers and they generally are a little to much less expensive to acquire. Radian does make a decent diaphragm for the 2440 at about 1/3 the cost of OEM, but it is not an exact equivalent. I like the JBL Pro stuff if that was not clear..
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#22 | |
What we are talking about is much like AC demagnetization of tape. You must run back and forth over numerous cycles and then have the field fade away to guarantee that it ends up in a neutral demagnetized state. You can't stop at zero either, due to hysteresis, so it is impossible to predict what the remance will be. You would have to get to the coersive level in the opposite direction to reduce to zero, and that is hard to control. If you give the unit an AC blast then the end point is undefined. Your final magnetization would be a crap shoot, hence several trials to get to the right point. David S. |
#23 | |
Thanks for the explanation and the references. The references would explain why I had not experienced the demagnitization in Alnico units I used: "Alnico was chosen because of its stable operating point. This material is insensitive to temperature changes and back-EMF from the coil. JBL has overcome the tendency of alnico to demagnetize at high power levels by utilizing a massive shorting ring at the base of the motor assembly." By the way, Crown introduced the DC-300 in 1967, and the M600 and M2000 in 1972. Can't find any reference to a D600. Like they say, if you remember the 1960's, you weren't there .Art |
#24 |
Confusing my Crowns with my Nikons. It was an M600. I think the M2000 was a couple of them bridged?
The "back EMF from the coil" would be a reference to flux modulaton distortion, as cured by the aluminum ring. Alnico is inherently imune to that and apparently better with regard to Curie effects (hot). Hard enough remembering the 70s! David |
#25 |
#26 | |
I never saw a M600/M2000 amplifier, just tons and tons of DC300s and the smaller versions. Bridged sounds plausible, looks to be as big as a Macintosh 2300. |
#27 | |
#28 |
I think there is some misinformation on this subject so I would like to clarify one point, and have a declaration from a professional
![]() That any audible difference between equivalent Alnico and ferrite drivers is due to the different magnetic properties of the materials seems reasonable but is actually incorrect. A ferrite PM can have essentially identical magnetic properties to the Alnico it replaces if it is dimensioned correctly (different from the Alnico of course). The historical performance difference was due to the conductivity difference. The conductive Alnico provided an Faraday flux stabilizer by default. For a ferrite driver that had to be added separately as an aluminium or copper loop. When a low quality speaker company just replaced the Alnico with ferrite then it would have had more distortion, hence the popular belief. For JBL and other companies that added Faraday loops then the ferrite drivers are comparable with the Alnico. Minor differences in temperature behaviour and improvements over time in other areas of course. Is that a correct analysis? Best wishes David |
#29 |
#30 | |
![]() Who says so? ![]() I started studying *Engineering* in the 60's , plus designing, building and selling Musical Instrument Electronics .... which I do until the present day
| JBL 2405 Alnico data | revintage | Multi-Way | 2 | 2nd March 2011 09:54 AM |
| FS: Coral alnico 6 inchers and Coral H-12c alnico tweeters | MichaelPublic | Swap Meet | 2 | 27th June 2008 11:24 PM |
| FS 2@ 15" JBL Alnico speakers | kjunom | Swap Meet | 5 | 3rd December 2005 09:39 PM |
| JBL 1500 Alnico x 2 For Sale | Merlin | Swap Meet | 0 | 13th February 2005 09:17 PM |
| JBL 1500 Alnico x 2 For Sale | Merlin | Swap Meet | 0 | 20th June 2004 08:11 AM |
