Need help reading blue prints for wood horns. - Page 2 - diyAudio
Old 29th January 2013, 03:09 AM   #11
djn is online now djn  United States
djn's Avatar
Originally Posted by GM View Post
Hmm, the distance from the focal point to the beginning of the flare is 34 mm and is [3] segments long, so seems it's 34/3 = 11.3333 mm between segments, but in the metric world this begs the question: 'why'?
GM
But then look at the segment between 4 and 6. Off to the left it indicates it is 20mm. So the segment between the crosshairs and 4 must be 14mm.
I just added to the CL with section 17, 18, and 19. Making the assumption that the section between the crosshairs and 4 is 14mm, and the sections are 10mm each, the total is 170mm just like the radius.
Old 29th January 2013, 03:12 AM   #12
Inductor's Avatar
GM
I'm trying to read it (in my metric universe) and doesn't show the starting point for segment #4. It should be/read 40 (something) if 1x segment = 10 (mm or something). (10 mm = 1 cm)
It shows only starting/ending point for measurement 34 (mm).
This for some reason shows that the source/starting point for segments #1, #2, #3, #4... it's not the same as the measurement (or segment) of 34 mm. In my logic world 1x segment #4 = 40 mm, away from "segment 34". Don't ask me why...
Old 29th January 2013, 03:14 AM   #13
puppet is offline puppet  United States
My guess is you're missing the sheet with the coordinate of each numbered point.
Old 29th January 2013, 03:23 AM   #14
Inductor's Avatar
I must admit that, if that's the beginning of measurement of segments, it's very logic. I just taught #4 was preceded by number 3, 2 and 1. Where are they?!
Old 29th January 2013, 04:01 AM   #15
djn's Avatar
Unfortunately, this is all they have for measurements. But here is the full print.
Old 29th January 2013, 04:02 AM   #16
frugal-phile(tm)
planet10's Avatar
The image attached in post #1 is not quite to scale. Except for one of the radial dimensions of the horn curve, the numbers seem consistant (the red segment shows where the curve is concave).
Dimensions are in mm except for the axis which is in cm. the centre of the arcs is at 2.6 cm
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th January 2013, 04:05 AM   #17
GM is offline GM  United States
GM's Avatar
Originally Posted by dumptruck View Post
Heh, well, I've still got this drawing open and that's easy to do... It doesn't seem to work out any less odd. I'm not sure where you're getting 3 segments for that, though, as no '0' mark is definite. Meanwhile, the 20mm deep section is clearly two segments, bringing it back to 1cm per segment.
Oh well........ From the drawing. I did say from the focal point, i.e. the radius arc and there's only one...... Yes, I noticed the discrepancy, but didn't know if the drawing was to scale, but figured you'd try it on your drawing, so nothing ventured, nothing gained. Anyway, it wouldn't be the first drawing ever done in multiple scales for tooling purposes or drawn over a scaled grid that I'm not familiar with.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 29th January 2013, 04:10 AM   #18
dheming is offline dheming  United States
dheming's Avatar
Why not just print out these plans full scale so that throat measures 25.5mm on the physical print. Then use a pair of calipers to carefully measure what the actual dimensions are every 1cm out. Seems like the best way to eliminate guess work, assuming the drawings are accurate of course.
Old 29th January 2013, 04:21 AM   #19
GM's Avatar
OK, so the segments begin 3 cm behind the focal point, but what arcs are at 2.6 cm, the ones at the mouth corners?
GM
Old 29th January 2013, 05:04 AM   #20
frugal-phile(tm)
planet10's Avatar
The centre/origin of the arcs are at 2.6 cm on the vertical axis, 14mm below the opening.
dave
Weak prints from a Samsung CLP-650N peranders Everything Else 7 2nd May 2010 05:41 PM
how to make spherical wood horns, step by step angeloitacare Multi-Way 0 29th May 2007 01:50 AM
Audiophile wood horns 1" nostrodan Vendor's Bazaar 0 13th February 2007 05:08 PM
wood horns for Klipsch LaScala karma Multi-Way 15 4th December 2006 10:49 PM
Copyright 1999-2017 diyAudio
