high efficency 5" midrange
Old 27th January 2013, 06:02 PM   #11
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
suprafox
http://www.supravox.fr/anglais/haut_parleurs/135_LB.htm
fostex fe125en
http://www.fostexinternational.com/d...df/FE126En.pdf
beyma 5g40
http://profesional.beyma.com/pdf/5G40%20NdE.pdf
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 27th January 2013, 06:22 PM   #12
Helmuth's Avatar
Scanspeak. Watch out 92,5dB 2,83V that is 2W because the impedance is 4 ohm. so spl is 89,5dB at 1 W.
Old 27th January 2013, 06:35 PM   #13
Helmuth's Avatar
davis 13mp5gr
doesnt look like 92db only 660-1600Hz
Old 27th January 2013, 09:12 PM   #14
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by Helmuth View Post
B&C 5MDN38
95 or 96 dB, that's one hot 5"!
I thought the Galaxy Audio S5N-16 was hot for a 5", but it's only 91 dB one watt one meter.
Old 27th January 2013, 09:17 PM   #15
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
At this size of mid-driver, you are bound to build a 4-way. Is that the intention?
But from now on I will be discrete about it.
Old 27th January 2013, 11:44 PM   #16
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Originally Posted by inertial View Post
hi guis, j'm desperate because don't find a decent 5" midrange. i need minimum 93-95 db. f3 is not important because the speaker is four way. if you know one, please, tell me the model. thery thanks in advanced. bay
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 28th January 2013, 03:22 AM   #17
Inductor is offline Inductor  Portugal
Inductor's Avatar
Default faitalpro M5N12-80
Product, Size, AES Power, Sensitivity, Freq.Range, XMAX, V.C. Diam., Fs, Magnet Mat.
M5N12-80, 5", 80 W, 99 dB, 1806300 Hz, 2 mm, 32 mm, 180 Hz, Neodymium
Old 28th January 2013, 03:25 AM   #18
ScottG is offline ScottG  United States
-smaller than a 5" driver, but lower mms as a result. (..it also needs only one narrow-band notch at around 5.1 kHz.)
The Madisound Speaker Store
perspective is everything
Old 28th January 2013, 03:27 AM   #19
Inductor's Avatar
sonomanie, CHECKED.
#6 & #8.
Old 28th January 2013, 03:37 AM   #20
murphythecat8 is offline murphythecat8  Canada
not 5 inch, 6.5 but 100db, audax pr170. amazing fella
high efficency 5&quot; midrangeHide this!Advertise here!
Using 12" guitar element as high efficiency midrange? Elias Multi-Way 53 30th June 2014 02:23 AM
WTB: 5" high quality midrange drivers tomstearns Swap Meet 0 20th September 2011 12:25 AM
high efficiency midrange tsmith1315 Car Audio 15 15th March 2009 11:02 PM
8" high efficency woofers - NEED HELP Miha Multi-Way 9 28th February 2007 01:43 PM
looking to build a high efficency, small speaker. demogorgon Multi-Way 29 20th December 2005 07:46 PM
Copyright ©1999-2017 diyAudio
