Hi, I would like to know if anyone has some plans for some mains using a reflex port that would sound great with one of the Fostex full range drivers (168, 206) and a tweeter.
I would love it to look like Doc's. http://www.pcdoctor.gr/newbluejpg.jpg Thank you. I do not want to create a rectangular box, put in the drivers and then hope for the best. I have ordered The Loudspeaker cookbook and hope they I can find equations for port length, and cross-sectional area for a slotted port. I saw this in a search of the forums http://audioreview.com/Learncrx.aspx Would slot porting to the front change the sound considerably? And I am thinking of the most simple design I can - With the full range driver and a tweeter using only 1 single capacitor on the tweeter. |
#2 |
I have just built some transmission line speakers using the Fostex 206fe driver. THe plans were from Martin King's Quarter wave website site. Easy to build and I am happy with the results.
I am at the early stages of running these speakers in, but can tell you that you will NOT need a tweeter with these drivers. They have a frequency response that extends to approximately 20K at a high efficiency level. I have had to peel back the trebble with Martin's correction filter as I have found them a little bright. If anything, I might even increase the resistor to peel them back further. But I have quite happy with the sound for the cost of the driver. Good imaging and a well rounded presentation. Not overly strong in the bass though so if you prefer rock music, I would consider alternative drivers. Looking at the specs for other Fostex (167,207,208 etc) their frequency drops from about 12 KHz so a tweeter may be required for these drivers. |
#3 |
This may be the sign I was looking for. I spent all day looking at every TQWP site I could find and I am very excited.
You do not think that your freq response will go down a little bit when you finish breaking in your drivers? I am looking at the Fostex 207 E (only difference is slight change in one spec and it is shielded). This accomplishes everything that I was looking for. A front slot port, floor standing (so no need to make stands), and simplicity in design and crossover. I really like the looks of these but I am going to wait to build my boxes till I get my Sound Cookbook in the mail and have a chance to really study the enclosure to determine optimal size for that driver and this type of cabinet. Found here: http://www.tnt-audio.com/casse/sloop_e.html[IMG] I like the base of these here - or I will do the suspended way. Just looking at the base here and not the rest of the speaker design. Would paint the bottom plate and stand-offs piano black with a cherry veneer for main body. I haven't downloaded mathcad yet but it is great that Martin King has these great resources available - I will be using that to help with cabinet size and shape. I prefer a 1.5 depth to baffle ratio over the more square look. Thank you again. |
| Fostex FE107E Plans for Vampyr | bobhowell | Full Range | 3 | 5th January 2009 09:50 PM |
| T Amp Fostex FE127E plans | st_eloi | Full Range | 4 | 1st May 2008 01:41 PM |
| Locating a bad resistor | engels | Tubes / Valves | 5 | 23rd July 2007 02:28 PM |
| Help locating some parts. | Destroyer OS. | Parts | 11 | 6th May 2006 06:39 PM |
| fostex 206e back loaded horns plans | spades | Multi-Way | 1 | 4th January 2004 05:36 PM |
| Page generated in 0.08748 seconds (75.45% PHP - 24.55% MySQL) with 10 queries |
