Surprise Charity Shop Bargain Sony 2 ways - diyAudio
Old 26th January 2013, 03:15 PM   #1
mondogenerator's Avatar
Default Surprise Charity Shop Bargain Sony 2 ways
Hi.
Inspired by several 'thrift store' and Dumpster threads, I randomly took a look around at what was in my local areas equivalent: the charity shop.
Lately these seem to be about the only shops that arent closing down, and in fact are showing up everywhere en-masse.
I found a worn pair of Sony 2-ways, likely from some system or other. polymer 10mm dome akin to the Audax (and clones), and a woven Kevlar/or polymer coned 5.5" bass driver. The box is ~4.5 litres and the port 80mm x 38mm diameter.
Next I thought id check out the tweeter and find what crossover there is in these little boxes.
Surprisingly, there is a 0.022 uF PP capacitor bypassing the 1.8uF electrolytic (which I expected to find). Not bad, I didnt think they would bother.
Next the woofer:
The nice thing about this woofer is the very open polymer frame, and rear venting of the spider.
Again, I didnt expect 'tech' like this on speakers like this, and for the money I paid the cabs alone are worth the expenditure.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 26th January 2013, 06:34 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
I bought some new sony speakers ~10 years ago for $40 for the pair. They had a 1.5uF 'lytic cap - upon replacing this with mylar and adding more damping material for a total expenditure of 20 minutes of time and $2, they are quite a bit better than anything I could build for the price.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 26th January 2013, 07:29 PM   #3
Thats my plan for these also.
In fact the 'lytic in my pair may also be 1.5 uF, but until i remove it its obscured and im unsure. Actually 1.5 would make far more sense. Thanks for the prod.
Im thinking of replacing the BAF with foam or felt. The woven cone is actually rather different to many ive seen. It appears to have no resin, and is surprisingly flexible.
Of course it isnt 'high end' gear and I have no idea of its response, but it sounds like a fairly good and smooth natural roll off. Maybe a bit of a midrange hole but for 10GBP im happy.
Im considering adding an Ohm or two to ease off the hot treble tizz that i expected from my experiences with the Audax formerless domes.
Old 26th January 2013, 10:44 PM   #4
Many years ago, speakers in this price/performance range had relatively poor drivers, a basic but "proper" crossover and solid enclosures. Nowadays they have quite good drivers, no crossover, and thin wall cabinets. The improvement in drivers has been mainly due to advances in design techniques. It costs little or no more to build a driver with a precisely specified set of parameters than it does to build a "generic". Designing a driver to roll off more or less smoothly at a defined "crossover" frequency alows doing away with the LF crossover components.
I too haunt "op shops", thrift stores and recycling centres. As you point out, some drivers are quite well designed and will perform very well in a solid enclosure with a proper crossover. The main problem is lack of T-S parameters, but a Woofer Tester 2 will quickly pay for itself.
Old 26th January 2013, 11:00 PM   #5
Thanks Don. I have a landscape gardener friend who's tight for cash, due to the last 2 weeks of snow we've had here. Luckily, he had been able to keep working until that point really. He needs a cheap stereo, in fact some cheap wharfedales at richer sounds. These were even cheaper, probably not as good, but not awful. Its now likely that i will sell them on. He's open to a cap change and pad for the tweeter, if it helps tone the tweeter down a little. Pennies in parts so why not?
Old 26th January 2013, 11:09 PM   #6
I forgot to even check for a model no. ss-ccpx11 I should search about a bit. From tinkering in WinISD i get an Fb of 80Hz for the box. Perhaps part of a system, but also handy to mate with a sub...
130 mile charity bike ride chris661 The Lounge 0 1st August 2012 11:32 AM
2 ways or 3 ways horn BMS coax or Raidian 950..etc..a newbie with too much questions hahayan Multi-Way 35 27th December 2011 11:13 AM
Charity sale of audio equimpent in Lawrence KS ByronInPortland Swap Meet 0 16th August 2011 06:29 AM
Need design help for charity auction jcbw Multi-Way 17 22nd February 2010 02:58 AM
Next set of bargain 2-ways cyberspyder Multi-Way 14 1st September 2008 09:17 PM
Copyright 1999-2017 diyAudio
