Old 17th November 2003, 10:09 PM   #1
Question Focal 10V6412 in Transmission Line
Bye .
I have small question, can it someone applied loudspeaker Focal 10V6412 in Transmission Line or in different application.
pa_nterka1@o2.pl
Old 17th November 2003, 10:30 PM   #2
qwad is offline qwad  Australia
If the QTs is around 0.30 yes!, you can use it in a TL IMHO perhaps others may shed more info for you as to other applications as I am not familiar with this driver...... cheers Tomcat
we all have problems only some people have more than most....
long live the Magyar (Hungarians) in the world!
Old 17th November 2003, 10:50 PM   #3
Vigier is offline Vigier  Netherlands
T/S Parameters of the 10V6412:
Re = 5.30 Ohm
Le = 1.30 mH
Fs = 37 Hz
Qms = 4.30
Qes = 0.40
Qts = 0.36
Rms = 2.20 Ns/m
Mmd = 37.47gr
Mms = 40.00gr
Cms = 0.45mm/N
Cas = 5.2e-07 m^5/N
Vas = 73.00 L
Sd = 340 cm²
BL = 11.20N/A
Pmax = 100W
Xmax = 16.5mm p-p
Airgap Height = 6.0mm
Voicecoil Height = 22.5mm
Efficiency = 0.89% --> 91.5 dB/1W/1m
Grtz, Joris
Old 18th November 2003, 02:08 PM   #4
http://www.focal.tm.fr/gb/compo/woofer/10v6412.htm
Here parameters 10V6412 are.
Fs 50 Hz
Qts 0,42
Sd 346,4 cm^2
pa_nterka1@o2.pl
Old 18th November 2003, 05:24 PM   #5
Hmm...that's pretty weird,
my parameters come from the lspCad Database, and they are NOT the same as the Focal homepage says...
Grtz, Joris
Old 19th November 2003, 12:44 AM   #6
GM is offline GM  United States
GM's Avatar
Using Focal's specs, a ML-TL looks good:
T/S max flat:
rp = 2"
Lp = 5"
density = 0.4lbs/ft^3
L (in)
29.941
S0/SL (in^2)
78.491
S0/SL (width)
11.270
S0/SL (depth)
6.965
X0 (in)
12.228
Sd (in^2)
53.692
Qts
0.4234
Vas or Vb(ft^3)
1.36
Fs or Fb (Hz)
47.6
All dims inside
'rp' = radius of port
'Lp' = length of port
'XO' = centerline of driver down from top
width/depth are golden ratio suggestions, you can make your own based on 'S0/SL (in^2)'
dims can be rounded off somewhat, I just printed out part of a spreadsheet
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
FS: JX 92S in Transmission line cab t-head Swap Meet 6 8th April 2011 05:29 AM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Focal 10v6412 castlesteve Multi-Way 10 19th July 2004 06:54 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Hi-Vi B2S Transmission Line BAM Multi-Way 1 14th August 2002 08:59 AM
Page generated in 0.08535 seconds (76.50% PHP - 23.50% MySQL) with 10 queries
