audiophile midrange ?
Old 25th January 2013, 04:03 PM   #1
jlm0924 is offline jlm0924  Cote dIvoire
Default audiophile midrange ?
Hi Guys, I'm going to be building 12" 3-way. I'm hunting for what might be the nice-est sounding midrange for under $500 usd. I'm aiming to use it 400-4000htz range. I Have limited experience with different mids of this caliber, and hoping some of you can help compare.
- the only mid on my radar so far is the accuton 3.5" (model #c90-6-790 i believe)
-(My previous systems I'm upgrading used scanspeak 7", and dynaudio 6" mids)
-Justin
Old 25th January 2013, 05:33 PM   #2
Hylle is offline Hylle  Denmark
For that frequence range you mention, I have good experince with Scan Speaks 4" units, 12M Revelator and 12MU Illuminator. they are very widebanded, and long stroke for a 4" midrange.
Old 25th January 2013, 07:59 PM   #3
ScottG is offline ScottG  United States
-Justin
If you can "cut" the upper octave to 2 kHz instead of 4 kHz (when considering dispersion), that would be the the BG Neo 10 ("open back").
Here are Dan's "Echelons":
Introducing: Echelon
Dan Neubecker Describes Echelons and Chameleons speakers - YouTube
perspective is everything
Old 25th January 2013, 08:14 PM   #4
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
I am using PHL.
High end THD and good efficiency so you can tune it down to what you need in your application.
Welcome on PHL audio web site
Visaton AL130M
audiophile midrange ?-al130m-jpg
eton
http://www.etongmbh.de/uploads/tx_pb..._375_32Hex.pdf
Audax HM170Z18
HDA-Aerogel Cone
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 25th January 2013, 08:42 PM   #5
Helmuth's Avatar
accuton
accuton® Carefully selected loudspeaker drivers.
Audiotechnology
C-quenze
C-Quenze 18 H 52 17 06 SD
BG neo 10
http://www.audax-speaker.de/index.php?module=shop_articles&index[shop_articles][action]=details&index[shop_articles][category]=11&index[shop_articles][data][shop_articles_id]=124
ATC SM75
http://www.google.com/url?sa=t&rct=j...41524429,d.d2k
Old 25th January 2013, 09:13 PM   #6
Helmuth's Avatar
exotic
suprafox 10"
215 RTF64 SUPRAVOX
audiophile midrange ?-schermafbeelding-2013-01-25-om-23-11-23-png
audax 10" hda cone.
HM210Z10
http://www.audax-speaker.de/index.php?module=shop_articles&index[shop_articles][action]=details&index[shop_articles][category]=8&index[shop_articles][data][shop_articles_id]=25
File Type: png Schermafbeelding 2013-01-25 om 23.11.23.png (637.5 KB, 1054 views)
Old 25th January 2013, 10:37 PM   #7
speakerdoctor is offline speakerdoctor  United States
R.I.P.
These are probably the best you can buy.
AUDIO CONSTRUCTOR Podszus-Görlich specialist
"It's all about the music!"
Old 26th January 2013, 09:31 AM   #8
ttan98 is offline ttan98  Australia
Satori from SB acoustics should be considered. It receives very favorable review from this thread,
http://www.diyaudio.com/forums/vendo...i-monitor.html
Old 26th January 2013, 09:35 AM   #9
StigErik is offline StigErik  Norway
StigErik's Avatar
The B&G RD-40 is just below 500$, and you'll save money on a tweeter... because you don't need it.
Bohlender Graebener RD40 Planar Transducer 264-706
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 26th January 2013, 01:04 PM   #10
studiotech is offline studiotech  United States
I'm going to endorse the BG Neo10 as well with the caveats:
DO NOT solder, use push on terminals. I'm a very accomplished soldered and even so, it seems I may have hurt a few of mine with repeated soldering. It's the only explanation for why their measured performance has changed so much since Zaph first tested them almost two years ago. My fresh one is perfect, but the three others all have issues. I have never soldered the new one.
See here for measurements:
Bohlender Graebenar Neo10 Planar Transducer | Medley's Musings
DO NOT use above 3KHZ and be steep with the xover. There is a resonance at 5KHZ that rings forever. It's not like the sound of a metal cone in breakup, but it's there and nasty if you let it through.
Follow those rules and it's world class used open baffle or in a well damped enclosure.
Greg
audiophile midrange ?Hide this!Advertise here!
You might be an audiophile if... c2cthomas The Lounge 46 20th October 2010 01:36 AM
DIY Audiophile Series: How to Make Your Own Audiophile Quality 300B Valve Amp (4DVD) scav Swap Meet 1 12th October 2009 03:14 PM
Serious Audiophile merlin2069er Everything Else 1 29th May 2009 04:28 AM
What every audiophile needs... pinkmouse Everything Else 2 16th March 2007 03:53 PM
