I'm looking for a sweet sounding tweeter under 50 to 60 bucks a pair that has wide dispersion but doesn't sacrifice quality.
I suppose it's because I've been goofing around with some cheap horns I have but I've come to like the spread-out sound more compared to the "highly directional" Vifas I've used in the past. Never have heard a ribbon tweeter (Beston?), and what's the deal with these Neodynium (sp) tweeters? -- just looking at their construction, seems I should look at these as well. What about the HiVi stuff? Can't really use a horn because I don't have the depth in my enclosures. Also, something in a mid/tweeter would suit my situation ideally. THANKS. |
#2 |
How low do you want to go?
HiVi RT1.3 is a gem at 2.8-3kHz+, LR4 or higher. I've used the Beston RT003C, but it goes to about 3kHz at the lowest, and rolls off SHARP below there. These are waveguided, so more directional than the others. Later, Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#3 |
#4 |
ive had a good experience with founteks' neoCD3.5H WG/Hornloaded ribbon used 3rd order or higher @ 3khz, or 2nd order @ 5khz.
Its wide horizontal pattern and narrow vertical pattern may work for you. Somewhere between the horns you had, and wide dispersion you seek. At 35 euro its also within your budget.
It still amazes me every time I get something right |
#5 |
wide dispersion tends to mean small- which tends to mean crossed-over high.
Above your price range are the HiQuPhon, which are 3/4" so have quite broad dispersion, they handle lower XOs than typical <1" domes, and have a very nice sound.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#6 |
wish I could find something a bit more inexpensive -- the HIVI and Fountek sound like winners but can't spare the money now.
#7 |
The price is a bit to high but good dispersion and not extreme expensive.
SB Acoustics :: SB26ADC-C000-4 ![]() ![]() ![]() http://www.eltim.eu/index.php?item=-...id=157&lang=NL http://www.eltim.eu/data/mediablocks...ifi%205-11.pdf Maybe Wavecor is cheeper. ![]() http://www.wavecor.com/html/tw030wa01.html http://www.wavecor.com/assets/TreeMe...er_units.html#
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 25th January 2013 at 10:08 PM. |
#8 |
the Fountek I have are great for the midrange price. They are only a 10mm 3/8" ribbon. Strangely in the datasheet 'dynanvox' is the maker.
There is certainly merit in dome tweeters and the HiQuPhon (of which im oblivious to) are certainly worth a look too. I find i like both domes and ribbons. A dome like Helmuth linked could be crossed low order, maybe even 1st (or damped LC)
It still amazes me every time I get something right Last edited by mondogenerator; 25th January 2013 at 10:02 PM. Reason: typing like a buffoon |
#9 | |
Something that has wide dispersion even at higher freq.s, mid-range usability, and is otherwise objectively *good*: doesn't exist. Limit the mid-range use and there are few choices.. Still, if you want all 3 then I'd recommend: Vifa NE19VTA http://www.zaphaudio.com/temp/Vifa-N...5-30-45-60.gif *with*: Vifa TC7FD00-04 http://www.zaphaudio.com/temp/Vifa-TC7FD00-04-FR.gif IF you don't care about objective performance there are BMR"s: HiWave BMR12 Compact 2" Full-Range Square Speaker 12W 8 Ohm 299-208
perspective is everything Last edited by ScottG; 25th January 2013 at 10:32 PM. |
| Controlled vs wide dispersion in a normal living room environment.. | Remlab | Multi-Way | 557 | 30th September 2012 01:27 PM |
| Ultra-wide dispersion drivers? | nonsuchpro | Multi-Way | 30 | 27th August 2012 11:41 PM |
| Wide dispersion speakers using full (wide) range drivers | ozziozzi | Full Range | 1 | 28th December 2008 06:13 AM |
| An idea for a wide dispersion ESL | jerko | Planars & Exotics | 25 | 29th November 2007 02:16 PM |
| Sub placement to counter wide dispersion? | kyrie48 | Subwoofers | 3 | 20th September 2007 04:33 AM |
