Dear all,
I built DIY Jim Holtz speaker statement. Some lately I found out that one side speaker (R) is louder than the other This happens after my PA blown out. The Right speaker seems still making a good sound but just feel dull I did change the cable from left to right to eliminate whether my eq is the one that causing problem. the result is still the same. How would I know that the speaker is broken (since still making nice sound just dull compare with the other) Should I check the cross over? tks |
#2 |
Tony, can you download or play some pink noise through the speaker at a safe level and use your ears near the drivers to see if a midrange is not sounding on the bad side? Figure that out first and then we can work from there.
Also, you might like to check over at HTGuide Mission Possible forum as the Statement designers are regulars over there. Greg |
#3 |
Its possible you have partly shorted the voice coil.
Check it with a DMM and compare with the good one. I had two speakers connected to a valve amp that went faulty and one speaker went quiet and the other was fine. When I checked the DC resistance one had dropped a bit.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#4 | |
Then you can tell where some sound is not coming from...which speaker exactly. As noted above: at a safe level.
Doug We are all learning...we can all help |
#5 | |
tks. Sorry I am a newbee |
#6 |
I took off the mid range
the R side (that sound lower) and measure with DMM both come out 6.4 Ohm The L side (that sound louder) and measure with DMM both come out 6.6 Ohm I think it should be ok right? |
| One channel louder than other | loudel | Tubes / Valves | 4 | 31st July 2010 10:58 AM |
| Why music really is getting louder | ash_dac | Digital Source | 5 | 5th June 2007 09:44 AM |
| Poweramp Needs Help Will Not Get Louder | prorms | Solid State | 7 | 7th June 2006 08:01 AM |
| One channel is louder than the other? | ble0t | Chip Amps | 30 | 12th June 2004 04:04 AM |
