Fostex full ranges as Midranges? in sealed?
Old 24th January 2013, 08:01 PM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
I like the FW137 5" midbass, tiny xmax which is ok as a midrange, and a smooth roll off, if i recall its around 4-5k. Take a look it may be a good choice.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 24th January 2013, 08:41 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by rhythmsandy View Post
one strange question why is the power handling of these drivers is very small? i feel very surprise that is that the real wattage? like for FE126 its 15W? strange I feel...
There is no standard for measuring power handling, so it ends up really being the domain of the marketing department. I ignore that number.
What Chris meant when he mentioned the FE108eS is that it might well be the best choice ($$ not considered) Fostex to use as a midrange.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th January 2013, 09:14 PM   #13
adason is offline adason  United States
adason's Avatar
I like FF125K full range as mid for 3-way speakers
Audio Pages: The way I like speakers these days
however, my aplication was a little bit different, I put the mid on open baffle, and used the mid in much large region, I crossed it from 180Hz up...it can hand it quite well, it is specified for 16 watts continuoes and 50 watts music, which is plenty considering its 92 dB sensitivity, I never play more than watt or two on it...
http://www.einklang-audio.com/treiber/fostex/ff125k.pdf
sadly its discontinued now, but if you select something similar from new fostex line, like FF125WK, you should have no problem to cover 400-4k, you can even go lower, I personaly like to cover widest possible response by midrange, and if you are using fullrange for the mid duties, why not...
The Madisound Speaker Store
Old 24th January 2013, 09:20 PM   #14
frugal-phile(tm)
planet10's Avatar
FX120 as midrange
Unifield Three Mk2 : Von Schweikert Audio
dave
Old 24th January 2013, 09:22 PM   #15
frugal-phile(tm)
planet10's Avatar
I have an R&D pair up for a song.
dave
Old 24th January 2013, 09:39 PM   #16
rhythmsandy is offline rhythmsandy
Originally Posted by planet10 View Post
fx120 has rated 10w as pow input but with music pow 30w so 10 is seriously low as it might blow up isnt it? or do we need to consider 30w?
Old 24th January 2013, 09:44 PM   #17
frugal-phile(tm)
planet10's Avatar
Let me repeat. Power ratings on hifi drivers are next to meaningless. Forget that they exist.
dave
Old 24th January 2013, 09:52 PM   #18
adason's Avatar
dave, how can von schweikert clain their speaker at 94 dB sensitivity when FX120 is 89 dB/w/m?
Old 24th January 2013, 09:54 PM   #19
chris661 is offline chris661  United Kingdom
chris661's Avatar
Don't worry too much about the power rating - by chopping off the signal at both ends, you effectively up-rate the driver as its receiving less overall power to achieve the same midband SPL.
I'd second everything Chris said about the FE126 and its presentation. IMO, you'd be better off with a dedicated midrange.
Old 24th January 2013, 09:58 PM   #20
How do you do that? increase the sensitivity
so you dont want FE126 to be used as midrange?
Fostex full ranges as Midranges? in sealed?Hide this!Advertise here!
TA2020 + Full ranges?? steve13 Full Range 12 1st February 2011 02:16 AM
Samco Full-Ranges mod_evil Full Range 2 24th March 2008 05:26 PM
FS: 1 pair Fostex FE-166ES-R full ranges zobsky Swap Meet 6 13th April 2007 07:57 PM
What should I do with these Philips Full Ranges? miccomacho Full Range 6 14th February 2007 05:25 PM
Full Ranges for Rock/Metal juan_caliente Full Range 17 25th June 2005 08:09 AM
Copyright ©1999-2017 diyAudio
