Old 24th January 2013, 04:49 PM   #1
diypass is offline diypass  Italy
Default Loudspeakers Binding Posts
i need of loudspeakers binding posts, make me crazy to find good performance/price.
please suggest me something
no Speakon
thank you
Old 24th January 2013, 05:00 PM   #2
zimmer64's Avatar
On my last project I used Speakon from Neutrik and really like them. Solid, pro grade, connectivity.
Best
Michael
Michael's Project Page
Old 24th January 2013, 05:03 PM   #3
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
I second that. No way beating Speakon
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 24th January 2013, 06:14 PM   #4
Bare is online now Bare  Canada
Best performance possible?? Solder the speaker wires directly.. with associated inconveniences .. But not that big a problem :-)
Next best and only a bit more expensive is to use Copper or Brass bolts as DIY speaker posts. Not impress your friends pretty though.
Save the $$ subsequently saved for music ?
Old 24th January 2013, 10:25 PM   #5
tvrgeek is offline tvrgeek  United States
I have come to just plain not using binding posts any more. I went back to barrier strips. I just tin my leads. I no longer use fancy wire either.
Old 24th January 2013, 10:44 PM   #6
OllBoll is offline OllBoll  Sweden
I tested speakon once and now I laugh whenever I see someone have to fiddle with binding posts =)
They are just too convenient not to use.
Old 25th January 2013, 01:07 AM   #7
ScottG is offline ScottG  United States
no Speakon
thank you
The best connector is no connector. Just clean wire and compress. The fewer connections, the better.
WBT has some very nice crimp sleeves for this (..though they need a good pair of "crimps", but it doesn't have to be WBT's though it should be very similar). Multi-strand works better with crimps, but you can use multiple runs of higher gauge wire.
If using copper wire use the copper sleeve, if silver (or plated silver), use the silver sleeve.
WBT has a better line of compression binding posts, but that end's up creating several connections - which isn't nearly as good.
perspective is everything
Old 25th January 2013, 05:10 AM   #8
like these guys : N.4 Connettori Altoparlanti Binding Post Professionali Hi-End Amplificatore | eBay
with alluminium plate
Old 25th January 2013, 06:53 AM   #9
Face is offline Face  United States
Face's Avatar
Why would someone want a large chunk of brass in series with their speakers?
I've given up on Vampire and Cardas copper posts and gone mostly to Speakon.
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen
Dayton binding posts and binding plate diypass Multi-Way 10 5th January 2013 07:03 PM
What Binding posts to get? aussiebuddha Full Range 19 10th November 2012 08:30 AM
Binding Posts ANDYLASER Swap Meet 7 23rd November 2006 11:33 AM
Binding posts cp642 Parts 6 16th November 2001 02:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
