Small driver, big cabinet, killer bass and efficiency - diyAudio
Old 24th January 2013, 01:32 AM   #1
diyAudio Member RIP
Default Small driver, big cabinet, killer bass and efficiency
I've been perusing the content of :
http://www.quarter-wave.com/Horns/BL...gn_Article.pdf
And it seems to me this is a way of doing several things with a small driver :
1) Avoiding BSC, that gives a big jump in efficiency.
2) Excursion control at low frequencies, basically a lot more bass given Vd.
3) Actually requiring placement in corners, not good with some designs.
Designed of course for FR drivers, but that doesn't stop you using
it with a decent efficiency, decent throw but not too low Fs driver.
An inverted driver arrangement is probably easiest.
Strikes me this should work well :
Zaph|Audio - ZA14W08 Woofer
Possibly the ZA5.2iw croosover from
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
Very big of course for the driver size, but some people like that.
And not perfect either, but a different ball game to a 10L box.
rgds, sreten.
Old 24th January 2013, 10:34 AM   #2
tvrgeek is offline tvrgeek  United States
Retracing the K-Horn at a small scale? Ironic, I was just commenting over there to the gentleman who wants a 15 inch midrange, Paul's main thesis was that distortion and efficiency are inversely proportional.
I am doing my third set of speakers with the Zaph drivers. Traditional ported this time. I was totally unhappy with them the first two times around. They hit an odd gap in the market which I am sure is why John had them built. He is not kidding when he warns you to notch or keep away from the breakup range. Below that, they are very clean for the money. I have two ideas this time around. Very low very steep crossover to an SB tweeter that goes about as low as any small tweet can, or a three way using a 3 inch mid and spreading the crossovers even further but low order. Maybe even first. (Is this Vanderstein's secret?) Building both ideas to compare. Wonder how that would work as a corner horn? Folded corner horn on the Zaph, big waveguides on the mid and tweet.
Another driver you may think about is the Planet 10 modified Fostex. I found they still need a tweeter, but they are as close to ultra wide range as I have seen. Mark Audio maybe? Zaph is a lot cheaper.
Post your progress. Sounds like a fun project.
Old 24th January 2013, 01:09 PM   #3
mondogenerator's Avatar
Sreten: may I ask why a low Fs driver would be an issue?
Im not all that au fait with BLH designs, and I ask since I have a quad of 5" drivers with Fs at 60-70 hz, my mains having Fs of 40hz. The former have got me thinking of interesting designs to get the best from them.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 24th January 2013, 03:00 PM   #4
Michael Chua's Avatar
The ZA14 is a good driver. The mids are exceptionally "clean", perhaps due to low harmonic distortion.
In a BR, with EQ (passive or active), you can get some nice bass out of it. Doesn't go down to 40Hz, about 50~60Hz (-3dB) but bass is tight and defined.
I have no issues with the cone breakup. 2nd or 3rd order at 2K2~2.5K is enough to bury it.
Mike
ampslab
Old 24th January 2013, 03:48 PM   #5
diyAudio Member RIP
By implication a low Fs would imply 5" drivers with parameters
too far off the family of drivers the BLH is designed for and I
wouldn't like to guess how well it would work or not.
Generally low Fs is low efficiency for a 5", and high Vas and Mms.
The Fostex is 89dB, 67Hz, Q-0.42, Vas-7.3L.
The ZA14W08 is 87dB, 66Hz, Q-0.44, Vas-5.2L.
Quite similar, the differences in Vas echo a 5g cone mass vs 7g.
I cannot check it with the worksheets, someone could.
rgds, sreten.
"All of the crossovers use a tiny cap across the first woofer
inductor as a trap circuit to kill the breakup a bit more "
Old 24th January 2013, 04:46 PM   #6
ah ha. Thats exactly what i did with my mains, 47uH in series with 5uF using visaton AL130. Worked a treat. Thanks for the reply, perhaps my old Audax AP130ZO with their aged Fs could work ok. Again thx.
Big bass from small power johnr66 Subwoofers 6 5th March 2010 03:40 PM
Full range and/or High Efficiency possible in small cabinet? Seraph Full Range 29 19th June 2007 01:13 AM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
Copyright 1999-2017 diyAudio
