Looking for recomendations on 15" woofers
Old 5th February 2013, 05:03 PM   #21
Inductor is offline Inductor  Portugal
Inductor's Avatar
I'm not interested, just posting a link for reference for other members.
OB 15" like was stated ""I am looking for a 15" woofer with a moderate cost and designed to play up to 1200 Hz.""
Celestion TF1525 15" Professional Speaker 300W 294-2084
LF Pressed Chassis / Ferrite - TF1525 - Celestion - Guitar, Bass & Pro Audio Speakers
Celestion BL15-400X 15" 8 Ohm Bass Guitar Speaker 400W 294-2460
Bass - BL15-400X - Celestion - Guitar, Bass & Pro Audio Speakers
Old 5th February 2013, 05:12 PM   #22
badman is offline badman  United States
badman's Avatar
Originally Posted by ScottG View Post
Beat me to it..
I think you both may be overestimating the effect- the onset of beaming isn't a brickwall, it's a mild transfer function, and won't be as big an effect overall as you seem to be predicting. Consider that CD 2 ways all have a lobe, and so if the woofer is suppressed off-axis, the waveguide output will play more of a role and counteract the beaming somewhat.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 5th February 2013, 05:13 PM   #23
DougL is offline DougL  United States
It seems the SEOS 15 has a recommended lowest crossover frequency of 850Hz so that might be ok. Haven't seen any plots though, it's just the manufacturer/dealers recommendation.
It has a 1" throat though and there are not many 1" drivers which can go that low.
I think BMS has a couple that get close
Extrapolating from the SEOS 12, it should be close. The Suma has the B&C DE250 crossed over at about 800 Hz.
So that should not be a show stopper. I agree that If I am crossing low, I have a very limited choice of drivers.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 5th February 2013, 05:24 PM   #24
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
For hifi it isn't a problem to cross low because the voice coil only sees a few watts. You have to look at thd at XO though this can become a problem.
I did try a DE25 sounded good like the beyma cp385Nd the titanium dome sounds a bit brighter.
http://profesional.beyma.com/ingles/pdf/CP385Nd.pdf.
18sound has great qaulity drivers to.
this is nice smooth.
http://www.eighteensound.com/index.a...simple&pid=266
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 5th February 2013, 05:31 PM   #25
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
that have been my thought too, but I'm less sure about it now
it does have its low ressonance point for a reason, I suppose
sorry if it's too much 'layman terms'
but it is ressonating because it does not like that frequency very much, right ?
Old 5th February 2013, 05:51 PM   #26
ScottG is offline ScottG  United States
I've shown the effect in the rather good design that was posted to.
Overestimating, not really - more caution with an alternative approach.
It really depends on the crossover, the horn and it's dispersion pattern at the bottom of its range, and the pressure loss from the 15" above its low-pass. For someone that has done this sort of crossover work a lot - it won't be difficult, BUT for someone that hasn't it might take awhile.
perspective is everything
Old 5th February 2013, 08:44 PM   #27
badman,
Thanks for your comments.
Old 5th February 2013, 09:14 PM   #28
Helmuth's Avatar
Resonance is the result of less air-load due the sum of suspension, area Sd plus xmax that is at its low-frequent limit and you put in signal with that frequency.
It is like a swing that every time gets a new push. And the air resistance of that swing isn't high enough to loose the energy to the air. So the impedance gets a peak there.
In fackt a driver will resonate on the resonance frequency it likes that because it loses stored energy the slowest at resonance frequency.
Old 5th February 2013, 09:37 PM   #29
Oh, I should also note that the size of the baffle in relation to diffraction peaking with a more "omni" nature makes a difference on the lower end of the crossover.
Basically in a 15" woofer to wide dispersion horn, assuming a low crossover point (less than 1 kHz) where the horn has lost most pattern control, it's best to have a small baffle for the woofer to match the wide dispersion of the Horn's output.
For other reasons it's also a good idea to separate the horn from the driver baffle as well (i.e. 2 part enclosure of Horn + Woofer with about 2-3 inches of separation provided the crossover is low enough).
If you need more volume for the woofer you can always do a double box with multi-pipe connection while still retaining the same diffraction profile of a smaller box.
Old 6th February 2013, 07:20 AM   #30
John_E_Janowitz is offline John_E_Janowitz  United States
Send a message via MSN to John_E_Janowitz
Originally Posted by Generic George View Post
By all accounts the TD-15M is an top class woofer, but you would probably need to be prepared to wait at LEAST 6mo to a year or more for them. If you do want some, your best bet is to try and find someone from the group buy he did last year who's plans changed or decided on different woofers due to the wait involved.
While I realize you are referring to the delays with the group buy woofers, please realize that regular orders coming in have not experienced delays like this and will not in the future. Over the past few months many things have had to happen within the shop that I will detail shortly on my forum. Throughout all of the changes and construction, nearly all production of woofers has been caught up nicely as well. The oldest woofers on the regular build list that haven't been made yet were ordered on Jan 22. Things are well back within the 2-4 week lead times on any new orders.
Out of the 250 woofers ordered in the group buy, about 40 are remaining to be completed. There will be 20 of those finished by early next week at the latest. I expect the remaining 20 to be scheduled in within the following 2 weeks around some OEM builds.
In addition I have a few TD15M-8ohm stocked that were built extra during the group buy builds. Those are able to be shipped immediately. I also plan to stock whichever TD12 is going to be most common for use with the SEOS12 waveguide.
Looking for recomendations on 15" woofersHide this!Advertise here!
Looking for recomendations on 15" woofers DougL Multi-Way 49 2nd December 2017 11:54 AM
Four (4) 15" GRS Woofers john65b Swap Meet 3 25th October 2012 06:02 PM
3 bass towers of 4 15" woofers exipnos Subwoofers 72 19th July 2012 03:44 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 04:53 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 11:15 PM
