Old 4th February 2013, 11:46 PM   #11
ScottG is offline ScottG  United States
Originally Posted by DougL View Post
Here is the other SEOS 12 + 15" woofer:
The "Sentinel" 15" B&C + DNA-360/SEOS-12 LCR design
Crossover 1100 Hz.
I may go with the SEOS 15" to better match the woofer.
That B&C driver may just have better dispersion than most 15" drivers..
Pretty good design.
You can still see though that the horn is loosing pattern control below 2 kHz. This basically means that from 900 Hz to 1.7 kHz will be "emphasized" ever so slightly. (..or "blooms" on a 3D waterfall.) Subjectively this often results in a forward mid-range with some loss in depth.
The 15 SEOS will allow a little lower crossover all-else equal.
As to which driver - why not try the Eminence you have? Can't hurt.
In your search you might also look at some of the less expensive driver's from MCM Electronics. At least one member was very happy with their inexpensive 10" pro driver, even when compared to more expensive drivers.
perspective is everything
Old 5th February 2013, 03:26 AM   #12
DougL is offline DougL  United States
Take a look at Eminence Deltalite
Thanks for the recomendation. I will look at them.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 5th February 2013, 04:41 AM   #13
Inductor's Avatar
although they don't go very deep
Model before you buy because they might need a big box too (if that's a problem).
It's very much volume dependent.
Old 5th February 2013, 04:51 AM   #14
ScottG,
Thanks for the comments.
I agree that the SEOS 15 is a better match. While the SEOS 12 are a bargain, the Solid surface SEOS 15 are attractively priced and a better fit.
Haven't bought anything yet, so I am looking at options.
I have never heard a horn I like(and have not heard many), but I find when there is a design that has a lot of good engineering collaboration, its worth building, even if it turns out not to be my thing.
Old 5th February 2013, 04:55 AM   #15
Thanks. Since I do not need a lot of volume, and have subwoofers, it should not be a big issue.
I can Linkwitz transform them in a sealed box to whatever I need, as long as I have some extra power.
Old 5th February 2013, 08:41 AM   #16
It seems the SEOS 15 has a recommended lowest crossover frequency of 850Hz so that might be ok. Haven't seen any plots though, it's just the manufacturer/dealers recommendation.
It has a 1" throat though and there are not many 1" drivers which can go that low.
I think BMS has a couple that get close.
Old 5th February 2013, 08:51 AM   #17
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
strange I thought I posted these in this topic.
Originally Posted by Helmuth View Post
For higher efficiency. 99dB wmtr -6dB 35HZ
Beyma 15lw30
And
18 sound 15MB606
15mb606
15lw30
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 5th February 2013, 01:34 PM   #18
Denovo BA-750 Compression Driver - Tweeters - Drivers DIY Sound Group
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is.
Old 5th February 2013, 02:07 PM   #19
Never really looked at their drivers since they don't sell to Europe.
The BMS driver I had in mind costs about the same but if you count in duty&excise (+28%) and VAT (+another 20%) it is a LOT cheaper even without shipping.
At least over here, no idea what the BMS 4550 costs in North America.
Old 5th February 2013, 03:56 PM   #20
Helmuth,
I did the rookie mistake of double posting.
Looking for recomendations on 15" woofers DougL Multi-Way 48 27th January 2013 08:47 AM
Four (4) 15" GRS Woofers john65b Swap Meet 3 25th October 2012 05:02 PM
3 bass towers of 4 15" woofers exipnos Subwoofers 72 19th July 2012 02:44 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 03:53 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
