Old 24th January 2013, 08:53 PM   #41
Thanks Helmuth!
Old 24th January 2013, 09:33 PM   #42
tvrgeek is offline tvrgeek  United States
Please note, my favorite little program, WinISD, is only good at guessing LF response in various boxes. It can't help at all with the high end roll-off and breakup issues. It can't help tell you about OB problems as that is a design of the baffle issue. IB can be simulated by a monstrously large sealed box. You have to MEASURE yourself the rest.
Don't know what speaker Helmuth has the plots for, but look at the scale! It would be embarrassing if this was one of the fore-mentioned raved about JBL's.
Old 24th January 2013, 10:37 PM   #43
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Sim of JBL2226G an the beyma 15lx60v2. both in same volume and br-tuning, as you see they are almost identical. Only the linear extrusion of the beyma is much bigger then the older jbl. So the beyma will have also low THD at high volume.
And again the beyma wins in the subbas area.
The rolloffin winisd is the result of the voice coil induction. It can be flat response in practice above the rolloff what you see in the simulation.
File Type: png Schermafbeelding 2013-01-25 om 00.35.59.png (41.0 KB, 152 views)
File Type: png Schermafbeelding 2013-01-25 om 00.35.33.png (39.9 KB, 152 views)
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 25th January 2013, 05:11 AM   #44
DougL is offline DougL  United States
Unfortunately all of the drivers have to obey the laws of physics.
This is all about trade offs.
The 15" pro mid-ranges trade low base extension and upper frequency cone breakup for efficiency and low distortion. Is it a good trade? I don't know. It depends on the skill of the designer and the style of the music, I suspect.
The Beyma looks like a great woofer.
Thanks to all who responded so far.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 25th January 2013, 10:30 AM   #45
Helmuth's Avatar
That is precise where it comes to. I have simulated a hole lot the last 10 years.
When you want more efficiency you get less subbas and the same the other way around.
I like beyma because they spec the second and third harmonic so one can get a idea of what you get.
Old 25th January 2013, 12:56 PM   #46
That's why I liked the look of the 15P80Fe.
THD in the low bass seems quite a bit lower than the 15LX60V2 although roles are reversed between 80 and 180Hz or so. They cost £155 and £130 (LX60) without VAT here respectively.
Old 25th January 2013, 01:39 PM   #47
Helmuth's Avatar
For higher efficiency. 99dB wmtr -6dB 35HZ
Beyma 15lw30
And
18 sound 15MB606
File Type: png Schermafbeelding 2013-01-25 om 15.36.30.png (33.4 KB, 1330 views)
File Type: png Schermafbeelding 2013-01-25 om 15.38.49.png (34.2 KB, 1225 views)
File Type: png Schermafbeelding 2013-01-25 om 15.41.34.png (33.4 KB, 1224 views)
Old 25th January 2013, 07:51 PM   #48
Helmuth's Avatar
15mb606
15lw30
Old 27th January 2013, 08:47 AM   #49
Helmuth's Avatar
We have to support the Greek economy to , look at the oberton 15b500.
and a other nice one 18sound 15nw530.
Four (4) 15" GRS Woofers john65b Swap Meet 3 25th October 2012 05:02 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 03:53 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
F.S.: (2)15" Magnavox Woofers and (2)Tweeters Sal Brisindi Swap Meet 1 1st September 2007 02:26 PM
Anyone used Selenium 15" Woofers? Cal Weldon Multi-Way 0 17th January 2004 12:12 AM
Copyright ©1999-2013 diyAudio
