Old 24th January 2013, 06:54 PM   #31
DougL is offline DougL  United States
I don't think using a 15 incher as a mid-bass is a good idea. you can simply go for a 12 incher of B&C or other nice woofs. IMHO
You may well be right. But I have enough reports of successes that I want to find out for myself.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 24th January 2013, 06:55 PM   #32
Helmuth,
Nice Woofer, but it doesn't look like it goes very high in your sym.
Old 24th January 2013, 07:21 PM   #33
1audiohack's Avatar
Originally Posted by tvrgeek View Post
The JBL's are probably the head of their class. I would encourage some measurements on mid-range response, decay, and breakup issues.
Another source of large cone high efficiency midranges are the full range driver offerings. These, like the big JBL, use a light weight cone that breaks up giving the impression of extended highs, but if you are looking for a 100 to 1K driver, one may do very well here as that range avoids the large excursion low end they can'd to and the midrange breakup they do.
It may simply be semantics but I think there is a difference between break-up and ringing "giving the impression of extended highs" and the progressive de-coupling of the outer portion of the cone allowing a light and low Le coil to continue to generate HF.
Old 24th January 2013, 07:26 PM   #34
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally Posted by DougL View Post
Helmuth,
I am often looking for high spl and subbas. The beyma was the best one I could find and not extreme expensive.
I would use it up to 500Hz but 1kHz is also possible.
File Type: png Schermafbeelding 2013-01-24 om 21.22.43.png (64.4 KB, 238 views)
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 24th January 2013, 07:32 PM   #35
Have you simmed the Beyma 15P80/Fe?
Going by Beymas data it looks a bit better to me than the 15LX60V2.
It costs about the same around here.
Old 24th January 2013, 07:36 PM   #36
Helmuth's Avatar
when you look at the THD of woofers they can have very low distortion at higher frequencies and very low extrusion that let them sound good.
Like this sm115/n not expensive at all and high end THD.
third and second harmonic around -55dB. The low and thd is sensational good.
File Type: png Schermafbeelding 2013-01-24 om 21.35.27.png (72.4 KB, 214 views)
Old 24th January 2013, 07:57 PM   #37
Helmuth's Avatar
Like I already thought the 15lx60v2 is best in band with and efficiency.
the 15p80fe (orange) can work in a small box but not as good at 30Hz as the 15lx60v2(bleu).
File Type: png Schermafbeelding 2013-01-24 om 21.51.24.png (42.4 KB, 124 views)
File Type: png Schermafbeelding 2013-01-24 om 21.51.07.png (39.7 KB, 123 views)
Old 24th January 2013, 08:04 PM   #38
Helmuth's Avatar
Here the SM115N the recommendation in price performence. Big box.
File Type: png Schermafbeelding 2013-01-24 om 22.01.21.png (38.7 KB, 19 views)
File Type: png Schermafbeelding 2013-01-24 om 22.02.55.png (40.9 KB, 19 views)
Old 24th January 2013, 08:43 PM   #39
ra7 is offline ra7  United States
I would go with the recommended jbls or eminence deltalite. Using them up to 1 khz may require some nifty crossover work. But if crossing at 700 hz or so, they will leave evrything behind.
Old 24th January 2013, 08:51 PM   #40
tvrgeek is offline tvrgeek  United States
Talking both things. Decoupling is the more desirable way they work, but breakup is another. Yes, "ringing" of different zones at different frequencies. The problem with decoupling is it means the cone is not working as a piston and the distortion will be much higher. It just plain is not easy! Just thinking bask on all the papers JBL has published on breakup modes, bell-mode, teeter-totter modes and dampening materials. They know what they are doing, but that still does not make using the wrong driver for the application that much better.
Four (4) 15" GRS Woofers john65b Swap Meet 3 25th October 2012 05:02 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 03:53 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
F.S.: (2)15" Magnavox Woofers and (2)Tweeters Sal Brisindi Swap Meet 1 1st September 2007 02:26 PM
Anyone used Selenium 15" Woofers? Cal Weldon Multi-Way 0 17th January 2004 12:12 AM
Copyright ©1999-2013 diyAudio
