Looking for recomendations on 15" woofers
Old 24th January 2013, 03:22 AM   #21
1audiohack is offline 1audiohack  United States
1audiohack's Avatar
I'm not thinking PA, more like large format studio monitors, think JBL 4430 or 4435. Those use 15" 2435's and 2234's and crossover at 1kHz. They are 2 way and 2.5 way. I'm listening to 4435's right now.
The 2220 has all the tricks for a low distortion midbass, thick top plate, underhung voice coil in a very thin precise gap and a light curvelinear cone, they just sound great. Next choice would be the 2234 then E130 (with a felt dust cap) then the 2225. I think all of them sound better than the 2226.
My last 2
Old 24th January 2013, 03:40 AM   #22
DougL is offline DougL  United States
My last 2
Thank you. This was the sort of information I was looking for.
I looked and JBL 2220 are not very spendy. Anything to look out for?
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 24th January 2013, 03:52 AM   #23
1audiohack's Avatar
Spend the time to find a nice clean pair. The cones are thin and will wrinkle if driven really hard and since the magnetic gap is narrow be sure the there is no voice coil rub or scratchiness. Is that a word?
There are 8 and 16 ohm units with AlNiCo and ferrite motors. Just be sure your pair matches. The 2220 motor is unique, you can put a 2225, 2235, E130 cone in it but it won't be right so be sure that what you buy is a proper 2220. The good news is they made a ton of them so with a little care and patience you should be able to find a real nice pair.
Old 24th January 2013, 06:19 AM   #24
Thanks for the Tips. I looked them up and see a Qts of .17 LOL, these beasts are not going to like an OB. But very interesting as a mid-base for what I was looking for in regards to the horn / waveguide projects.
Old 24th January 2013, 11:18 AM   #25
tvrgeek is offline tvrgeek  United States
Another detail often overlooked: A studio monitor's job is to help the engineer find anything wrong with the mix. It is a tool. Classic was the old L100, home version of their studio monitor. Man could it make problems in the midrange jump out into a horrible scream. Not what I want in my living room. The LS35a was another famous example. As speaker drivers have made great advances in the last decades, we can now build monitors that are highly accurate instead. It might make the engineers job a little harder, but can lead to even better results.
The JBL's are probably the head of their class. I would encourage some measurements on mid-range response, decay, and breakup issues. I have only heard them and not measured them, but I am confident what I hear is easily measurable.
Others may follow what Klipish published many years ago showing that all things being equal, distortion and efficiency are inversely proportional. This would give the inherent edge to high efficiency systems like the JBL's. (horn and waveguides included) I would love to hear the GedLee systems to see what Earl has done with modern drivers that Paul never had the advantage of.
OB at LF seems pointless to me as at low frequencies, the speaker is basically omnidirectional already. For those who don't understand how boxes work or have been led to believe there is something "boxey" about the sound, there is quite a following of IB for low frequencies. Look up The Cult of the Infinitelly Baffled. Again, go see what Linkwitz did with his 10's in an H frame OB. BTW, the Peerless carbon/paper 10's and 12's are very very clean drivers and can actually reach the low hundreds cleanly. They are not efficient or cheap.
Another source of large cone high efficiency midranges are the full range driver offerings. These, like the big JBL, use a light weight cone that breaks up giving the impression of extended highs, but if you are looking for a 100 to 1K driver, one may do very well here as that range avoids the large excursion low end they can'd to and the midrange breakup they do. Look at the 8 and 10 inch offerings. They may be well out of your price range though. I bet the "pro" 8 inch midranges are a better value.
Old 24th January 2013, 11:31 AM   #26
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
usher 15" I do not know the type number not cheep.
Beyma 15lx60v2 best one for good low end and good SPL.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 24th January 2013, 11:48 AM   #27
Beyma 8G40
Old 24th January 2013, 03:09 PM   #28
oldies is offline oldies
Banned
I don't think using a 15 incher as a mid-bass is a good idea. you can simply go for a 12 incher of B&C or other nice woofs. IMHO
Old 24th January 2013, 05:43 PM   #29
Helmuth's Avatar
USHER 15HM Studio
See sim beyma. -6dB 26hz 96db 1Wmtr.
File Type: png Schermafbeelding 2013-01-24 om 18.41.07.png (33.5 KB, 292 views)
File Type: png Schermafbeelding 2013-01-24 om 18.42.54.png (31.9 KB, 294 views)
Old 24th January 2013, 07:51 PM   #30
My #2 project is a GETLEE Suma Homage using the 15" SEOS Waveguide and a 15" midbase. Earl uses the B&C 15TBX100, but I was thinking that I could use an equivalent JBL and get simular results, since I didn't need a new driver.
Here is the waveguide Solid Surface SEOS-15? - SEOS? - Resin - The SEOS? Project DIY Sound Group.
I have made two Orion "clone" speakers to hear what the fuss was about. I read Linkwitz Lab - Loudspeaker Design My bottom line is that I like the sound, but its expensive, requiring about 4 times the woofer displacement for the same performance.
Interesting Idea. I will look to see if I find something I can use.
Looking for recomendations on 15" woofersHide this!Advertise here!
Four (4) 15" GRS Woofers john65b Swap Meet 3 25th October 2012 06:02 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 04:53 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 11:15 PM
F.S.: (2)15" Magnavox Woofers and (2)Tweeters Sal Brisindi Swap Meet 1 1st September 2007 03:26 PM
Anyone used Selenium 15" Woofers? Cal Weldon Multi-Way 0 17th January 2004 01:12 AM
