Looking for recomendations on 15" woofers
Old 23rd January 2013, 08:50 PM   #11
DougL is offline DougL  United States
There's a pair of 2226H for $300 in the sale section. Buzzford or someone. Can't recall the exact spelling of his nick.
Thats a fair price for those.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 23rd January 2013, 09:15 PM   #12
Dave Zan is offline Dave Zan  Australia
Default JBL 2226
I think you have an excellent candidate here.
Low distortion, smooth and flat, efficient, excellent output capacity with minimal power compression. It is a mainstay of the JBL pro line for a reason.
Whether the same driver is optimal for all your applications will create (interminable) debate but this one will do it.
Specifications show they are very well matched to 1.5" throat compression drivers. JBL practice and my own system verify this.
Best wishes
David
Old 23rd January 2013, 09:32 PM   #13
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Faital Pro 15FH510 ferrite
FaitalPRO | LF Loudspeakers | 15FH510
or 15FH500 neo
FaitalPRO | LF Loudspeakers | 15FH500
If I'm not making noise, I'm making something to make noise
Old 23rd January 2013, 09:59 PM   #14
1audiohack is offline 1audiohack  United States
1audiohack's Avatar
I don't know anything about your DCX2496, does it have EQ? If so do/will you use it?
My 2bits, since you have subs and don't need the bottom corner, consider the JBL 2220. My absolute favorite 15" mid bass driver, very clean. It has rising response and requires some shaping to be flat but when integrated properly its near impossible to beat.
My opinion is formed from long term listening/ownership of the following JBL 15's:
2220
2225
2226
2227
E130
E140
You should be able to find a clean pair within your budget.
Old 23rd January 2013, 10:43 PM   #15
Nice. A bit out of my price range, but a posibility used.
Old 23rd January 2013, 10:48 PM   #16
tvrgeek is offline tvrgeek  United States
There is no one right answer. Badman and I seem to have quite a different view of a great midrange. The advantage of this forum is you get several ideas to think about. I will agree the value of the Dayton is excellent. It has features you don't get at twice the cost like the copper shunt and with the exception of my Titanic III's I have been very happy with all the Dayton's I have used. Mostly RS series.
You did not say if you were building a PA system or a home music system. I stand by my view of 15's as they will have breakup problems way before you get to the mids. Beaming is only an advantage in a PA. Yea, the market is full of 12 or 15 inchers and a horn for a cheap PA, and well, to my ears, they are horrid. Even the not so cheap JBL's. So for a PA, I would use my favorite solution, a line array. Not always cheap though. For a home music system, all of what is discussed here is completely against my preferences.
For a home system in the vain of a big cone PA, go look at the GEDLEE work. Now their stuff is not cheap, but it has valid ideas.
Old 23rd January 2013, 10:51 PM   #17
Thanks for the response. The DCX 2496 has extensive but not unlimited parametric EQ.
I will look at the JBL 2220. Also I'll see if any are currently up for auction.
I do see JBL 2225 H/J close to my price range. What is your experience with them?
Old 23rd January 2013, 11:10 PM   #18
The DCX has very poor eq capabilities and you run out of memory real quick. Basically, it can do a three way crossover, one notch and maybe have enough left over for a delay. For the input channels, it can only notch, not boost. They want to sell you a DEQ for that. Remember, it is designed to help tame PA speakers as one step up from a simple analog crossover. That it can do more is quite a complement. I find it noisy, ugly when it turns on, and not at all a hi-fi component. Really handy on my test bench as it allows asymmetrical crossovers where the simple analog ones do not. The A2D, D2A is not the biggest problem in it. At least the DAC portion is not half bad.
Old 23rd January 2013, 11:19 PM   #19
This is a home system. The waveguide discussions on DIYAudio have made me want to see for myself what I like.
Since I have an electronic crossover and 6 channels of amplification, I want to try some of these things for myself.
The SEOS project (#2) is a variant on the GEDLEE technology, being a Super Elliptical Oblate Spheroid waveguide.
The third project is a cost reduced Lynn Olson inspired project.
Both of these push a 15" driver until the directivity matches the horn / waveguide.
I agree the Dayton RS drivers have been a great Value.
However, The cone breakup on the metal drivers severely limits their use at extended frequencies.
At this point I am more interested in trying different approaches than anything else.
Thanks for your experience.
Old 23rd January 2013, 11:33 PM   #20
I am doing a 3 way with a base shelf, a mid-base low Q notch and some HF boost.
I am probably close to the memory limits. I will look.
I applied some cleaner to the ribbon cable and its been quiet for the last 3 or 4 years.
There are probably lots of crossovers that sound better, but up till now it hasn't bothered me.
Looking for recomendations on 15" woofersHide this!Advertise here!
Four (4) 15" GRS Woofers john65b Swap Meet 3 25th October 2012 05:02 PM
using a wall of 15" woofers for bass. noviygera Subwoofers 2 25th August 2009 03:53 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
F.S.: (2)15" Magnavox Woofers and (2)Tweeters Sal Brisindi Swap Meet 1 1st September 2007 02:26 PM
Anyone used Selenium 15" Woofers? Cal Weldon Multi-Way 0 17th January 2004 12:12 AM
