To those who have built Goldwood 18" OB H Frame...
Old 26th January 2013, 03:09 PM   #11
mortron is offline mortron  Canada
There are som impressive reviews I've read here and there about those widow makers as well, and part of the reason two ain't a bad idea I think hahaha
Old 27th January 2013, 03:10 AM   #12
What would be the effects of increasing the height and width of the Hframe by 2"? 4"?
Old 27th January 2013, 04:27 AM   #13
Pano is offline Pano  United States
Pano's Avatar
Not much I would think. You'll change the peak and the f-equal a bit, but not in a big way.
John usually says that baffle surface area affects dynamics and the long dimension affects the low end roll-off.
The thing that immediately hits you about a speaker with this size baffle and this much cone area is not huge bass, but huge scale and ease of presentation. It sounds big, and it sounds effortless, real. A lot of fun.
Take the Speaker Voltage Test!
Old 27th January 2013, 04:52 AM   #14
freddi is offline freddi  United States
freddi's Avatar
any details on the widow maker's crossover? - my H-baffles have sat for a few years as I piddled with other stuff - my Eminence lil' Buddy ought to make a useable midrange
Old 27th January 2013, 05:29 AM   #15
Pano's Avatar
I may have details somewhere, but I'll see if I can get John to chime in.
Old 27th January 2013, 05:48 AM   #16
I see you used 21" baffles... the original MJK artocle specified 20" square... was there any reasn for the change?
To those who have built Goldwood 18" OB H Frame...Hide this!Advertise here!
MJK’s Jordan JX92S OB with a Goldwood GW-1858 Woofer in an H Frame Jim Shearer Full Range 608 21st October 2014 03:09 PM
U-frame with 18" PA driver capslock Subwoofers 0 25th September 2012 08:58 PM
Suggestions please on OB with 15" H frame syyma Full Range 21 31st July 2011 12:07 AM
FS: Goldwood GW-1858 18" woofers - $110 xecluded Swap Meet 6 28th May 2010 03:13 PM
Goldwood 18" for OB sub bbaker6212 Multi-Way 23 17th March 2004 09:36 AM
