Yamaha NS-1 vibrating
Old 23rd January 2013, 09:19 AM   #11
fatmarley is offline fatmarley  England
A mate used a bicycle puncture repair kit to fix the rubber surrounds of his speakers. He used a piece of condom (a new one) for the repair.
If it was me, i'd remove the driver and do it from the inside.
Old 23rd January 2013, 09:22 AM   #12
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
A perfect solution. Puncture repair outfit.
Old 23rd January 2013, 03:05 PM   #13
ianp is offline ianp  United States
Genius. I believe I have some puncture repair kits in the garage. Hopefully not the ones with the pre-glued patches.
So just the adhesive or should I also look at using part of an unsoiled French letter or some other form of patch?
Ianp
Old 23rd January 2013, 06:01 PM   #14
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
rubber solution should work too like evostik or even perhaps copydex. A piece of linen, inner tube rubber or the like should work ok.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 23rd January 2013, 06:50 PM   #15
I generally use just the rubber solution. A patch will ressonate.
Old 23rd January 2013, 07:56 PM   #16
Thanks All.
I found a couple of tubes of finest rubber cement in the bicycle repair kits, so will effect a repair.
ianp
Old 23rd January 2013, 08:19 PM   #17
Some images of the interior.
Even after removing the 3 screws holding in the lower speaker it remains well stuck into the enclosure. I decided to just apply the rubber cement to the outside of the speaker at this point. It should be possible to dab some glue on the split from the inside without removing the speaker, but it would be an ugly blob. That'll be the next step I guess.
ianp
Old 28th January 2013, 11:32 PM   #18
Just to follow up. I used the rubber cement just on the outside of the diaphragm and this seems to have fixed the issue.
Thanks to all.
ianp
Yamaha NS-1 vibratingHide this!Advertise here!
Yamaha NS-1000 Moondog55 Multi-Way 2 25th March 2012 02:28 PM
FS: Yamaha NS-590 Speakers (Small version of NS-1000) rca9449 Swap Meet 0 23rd August 2007 03:57 AM
yamaha NS-200M mack2 Multi-Way 8 27th April 2007 05:37 AM
yamaha ns m-50 RogerG Solid State 13 24th March 2007 12:10 AM
Yamaha NS-8390 zafira1981 Multi-Way 4 26th January 2006 12:58 AM
