Help with speaker planning / selection for family room - diyAudio
Old 21st January 2013, 06:41 PM   #1
jmroach is offline jmroach  United States
Default Help with speaker planning / selection for family room
Ok, so I must preface this by stating that the "heard, but not seen" adage definitely applies here. Wife just decided to add a tv to the main entertainment area in our house. It's a large (20x35ft) room with high, vaulted ceilings. Seating position is about 13ft from the tv and the tv is on one of the long walls of the room. Use will primarily be tv and movies (but we already have a theater in the basement). Speakers will be powered by a marantz nr1603.
The main constraints are created by the tv stand (pics to follow). From what i can think of, It essentially requires a low-profile center channel to be housed either above or below the tv. I was tentatively planning this design for the center channel and something similar mounted in the wall on either side of the stand for a 3.0 system.
I'm definitely open to suggestions, help, & critique!
Thanks,
-john
Old 21st January 2013, 07:32 PM   #2
I quite like the look of these - Speaker Design Works
You may recognize the drivers here: Click
IIRC someone used one as a centre channel speaker.
Troels has a good very selection of diy speaker designs to suite all budgets.
Old 21st January 2013, 08:01 PM   #3
A couple pictures of the room...
Old 22nd January 2013, 12:47 AM   #4
xjr100 is offline xjr100  Europe
Think about on-wall panels.
You can get some ideas from Artcoustic:
Design high-end wall Loudspeakers and Subwoofers by Artcoustic
Auricap XO, Mundorf, Jantzen capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 22nd January 2013, 07:36 PM   #5
I had thought about on-wall vs. in-wall and didn't think it would be a viable option due to looks, but I'm beginning to come around. Any idea what they use as the "oversized baffles"?
Old 22nd January 2013, 07:50 PM   #6
DrDyna is offline DrDyna  United States
DrDyna's Avatar
The little Magnepans might look good in there if you need something that's not a box, but they're a little anemic without a sub.
Maybe something like this: Dayton Audio ES80W 8" 2-Way In-Wall Speaker Pair 300-372
Edit: The design using the markaudio drivers is kinda cool, but again, as stated by the designer of the markaudio drivers, "They are not woofers." They're not really designed to play much below 50-60 cycles with any amount of authority and asking them to play loud is probably not a good idea.
Old 22nd January 2013, 07:54 PM   #7
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
Hi, worth a look just to see how the design changes for the various options, rgds, sreten.
Old 22nd January 2013, 08:50 PM   #8
Melo theory's Avatar
I've owned these before, for a 5.1 set up
Mirage : Bookshelf Speakers : OSł-Sat
BIG sound small speaker. Needs a sub.
I liked them better than my magnepans mmg's
I LIKE YOU
Old 5th February 2013, 03:47 AM   #9
update: on-walls are out. a sub is out.
so i'm basically left with in-wall speakers on either side of that tv stand thing and one center channel under the tv. The CC seems rather straightforward given that i have plenty of depth and don't need it to go below ~80 or 100 hz.
I'm stumped and would definitely appreciate a nudge in the right direction on the in-wall speakers. i can't find anything anyone has built/designed that narrow (3.5in - 4in) that is still going to have decent bass response. another constraint: any port needs to be close to the driver so i can cover with one grill.
is this possible?
Old 5th February 2013, 11:44 AM   #10
DrDyna's Avatar
is this possible?
As far as I know, In wall speakers are all of the infinite baffle type, so you won't have to worry about ports. If you're looking for a diy in-wall setup, I'd send you to the page mentioned by sreten, here: Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
There are some variations of these if you scroll down that are designed for in-wall.
Edit: You'll probably have a tough time with ~4" of width, your life gets a lot better around the 7-8" widths for main speakers.
25mm Speaker selection Techatronics Everything Else 0 19th July 2012 08:28 PM
Speaker Selection wdcw Multi-Way 1 27th February 2011 12:58 AM
new on-wall speaker for selection denbo123 Multi-Way 0 3rd August 2006 03:30 PM
Speaker selection help lbreevesii Multi-Way 0 1st April 2006 04:14 PM
Speaker Selection? Jeroth Multi-Way 94 18th June 2002 02:41 AM
Copyright ©1999-2017 diyAudio
