Help wiring x-over into bassbin - diyAudio
Old 19th January 2013, 12:26 PM   #1
Default Help wiring x-over into bassbin
I recently bought a set of Wharfedale DLX 15B bassbins. Unfortunately the previous owner removed the x-overs and left no trail behind how it was connected.
Can anyone assist me please?
Old 19th January 2013, 04:02 PM   #2
Inductor's Avatar
Hi, I can only guess you have a 1. order inductor filter to the woofer and a HPF (high pass) 2. order for the mid/high output.
So from AMP to LPF and HPF:
LPF is the coil in series with the woofer driver,
HPF is the second order (not for the woofer driver) you have the layout on your draying.
Does this make any sense to you, can you interpret the drawings and the concept?
File Type: jpg 12 dB per Octave Crossover Table Values.jpg (34.5 KB, 58 views)
Old 24th January 2013, 07:54 PM   #3
Inductor's Avatar
Was this of any help? Maybe you are lost in your project?
Passive crossover is a Hi pass out (passive) with an external switch for bi-amp/passive modes. It's very likely that the passive high pass crossover it's a 120 Hertz 2nd order butterworth but this needs a big coil (4/8 Ohms?). Pictures are always very helpful...
Wharfedale DLX-15B
DLX SERIES BROCHURE
DLX SERIES MANUAL
Old 27th January 2013, 08:15 AM   #4
Old 27th January 2013, 04:09 PM   #5
Inductor's Avatar
It's funny not knowing if you were successful connecting the crossovers or not ?!
The amazing thing is that the 2. order could be a Hi Pass for the out speaker (Mid/Hi Output) or for the low frequency (30Hz) protection of the woofer.
Hi Pass:
CAP1 (208uF)+CAP2 (330uF)= Total ~127uF
Inductor (value?)
In this case (if having in mind) it's the crossover for the output high pass then it's similar to this. Sorry but I don't have all the details/connections and values/components and impedances for the speakers. (Some crossovers also have a switch for the 4/8 Ohm impedance, they internally disconnect crossovers parts but I think it's not the case)
A simple and easy test is to connect the crossover to the main woofer/sub.
If the sound is coming with mid/high frequencies only then its a high pass for external speaker (no low/sub frequencies contents).
The other coil should be the woofer coil. This his the logic. but could be different. You only show a picture (one picture and one side only) and thats not enough to guess.
Old 27th January 2013, 04:13 PM   #6
Inductor's Avatar
Make sure the caps are connected in series and not in parallel what would make things different.
Old 28th January 2013, 08:40 AM   #7
wolf_teeth's Avatar
Default I would guess...
12dB lowpass and 1st order highpass. I don't think we're seeing the circuit correctly.
Picture of back of PCB please?
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 28th January 2013, 07:03 PM   #8
The first picture I posted is a schematic I made from the underside of the board.
Need Wiring help benk016 Subwoofers 11 12th August 2011 12:23 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 03:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
wiring whiteboy Subwoofers 2 5th May 2005 10:51 PM
Copyright 1999-2017 diyAudio
