Great speaker tool: REAL-TIME DSP crossover adjustment! - diyAudio
Old 18th January 2013, 06:19 PM   #1
Default Great speaker tool: REAL-TIME DSP crossover adjustment!
It's ... miniDSP! I saw the ads but I didn't realize it has a 'synchronize' function so you can adjust the crossovers in real time while listening!
The 2x4 (miniDSP Kits | miniDSP), for $100 + $10 for the 2 way software plugin, takes 2 analog inputs and puts out ... you guessed it, 4! Perfect for a simple, easy stereo two-way.
I had a BLAST over the break playing with my old open baffles; the most audio fun I've had in years!
Beta15 on the bottom and on top: FE83, RS1197, PR170MO + APT80, Beta12LT + RS pod tweet and then Wayne's 1 Pi, 2 Pi (sort of) and 3 Pi front baffle.
High level of flexibility: correct open baffle, notch resonances, correct driver response, xover point, slopes (BW6-24, LR12-48, Bessel ..), delay, attenuation ...
The 2 way plugin interface starts with digital atten, then 6 filters of pre eq, then crossovers, then 6 more filters of eq, then atten and delay. Whew!!!
Awesome! Doing this analog would take forever (passive), awhile (active), or a bit (Pass/Marchant variable xover) but with DSP it's click click click ... go!
The 2x4 puts out 0.9v and accepts 2v or 0.9v in (jumper!) so I was able to hook up my CD player, DACS, USB DAC and turntable too! I didn't get into it but you could add a rumble filter etc ... and also shape frequency response of your phono! !
I was using it mostly as a lower crossover at 100 to 500 Hz but also tried 1.6k on the 3 Pi.
Oh yeah, it also has a digital (24bit) vol control ($5 pot) so you can use the top part of volume knob without touching the actual 16bit CD resolution! !! !
Next I'm going to try 3 and 4 way by getting the 4-way plugin for an extra $10. With it the 2x4 can be easily reprogrammed to become a 1x4 (1 in and 4 out). !!! !!!! !! This of course means it's not stereo anymore but that's ok for testing for now.
Then I'll get another 2x4 so I'll have a stereo 3/4 way and then go full digital with the $70 miniDigi (2 coax and 2 optical SPDIF ins that connect directly to one or two 2x4s)!!! !!
More to come!
Jeff
PS Just a happy customer, not with the company blah blah blah ...
Last edited by AudioLapDance; 18th January 2013 at 07:10 PM. Reason: move pics, add extra !!! 'cause I'm so happy!
Old 21st March 2015, 01:00 PM   #2
xrk971 is offline xrk971  United States
xrk971's Avatar
Totally agree. MiniDSP changed my life. Seriously.
So easy and so fast to make a good FAST.
Nice assortment of drivers there. What did you think of the RS1197?
Old 21st March 2015, 01:13 PM   #3
I've been using one for two years, and I just recently built my first passive crossover speaker. I did all the crossover frequency and slope selection, driver level adjustment and voicing using the miniDSP. It is really fantastic to be able to listen to one potential crossover and nearly instantly (about 1/2 sec) switch to another while listening to music by using the save/load features..
After I am satisfied, I measure the response of each driver with the dsp crossover in place, and then make the passive match on each driver as well as I can.
You can also do a single three or four way by using an RCA Y-splitter and feeding the same signal to input 1 and 2. I have done that, before I got my second 2x4.
Marc
Old 21st March 2015, 03:07 PM   #4
i cant think of a product with better price/performance ratio than the 2x4. even some "high end" passive brandnames could be somewhat improved with this one. since they are all restricted by ohms law, box physics etc.
Old 21st March 2015, 06:24 PM   #5
xrk971's Avatar
Marc
They also sell a 1x4 advanced 4-way XO plugin for $10. Almost as cheap as a Y splitter plus you don't lose signal amplitude.
I agree that even for people who are passive xo diehards - the miniDSP is great for testing and picking the optimal one and for voicing before making a passive implementation.
Old 21st March 2015, 07:12 PM   #6
SaSi is offline SaSi  Greece
To the OP, a quick question:
I understand that settings can be viewed and altered from a computer via USB. Once happy with the settings, is it possible to disconnect and let the minidsp run by itself disconnected from the laptop?
Old 21st March 2015, 07:16 PM   #7
pguerin is offline pguerin  France
Short answer : yes
Old 22nd March 2015, 12:39 AM   #8
With the 4x10HD, you can have four different configurations loaded up and switch between them with one click. It has been interesting to compare two configs with identical EQ on each driver, but different xover slopes.
Bill
Insert witty signature line here.
Old 22nd March 2015, 01:00 AM   #9
Greebster's Avatar
You should note that the 4way advanced plugin XRK mentioned allows you to switch between two inputs the 2x4 has. I've used this config for the last two years.
Also note you cannot control more than one 2x4 via usb at a time. So tweaking in stereo will not happen. It's a small pain to deal with.
Old 22nd March 2015, 01:17 AM   #10
bwaslo is offline bwaslo  United States
bwaslo's Avatar
They also have an OpenDRC series that can do the same type parametric EQs as well as FIR filtering or crossovers. For if you want to independently adjust phase responses, too, using Rephase freeware. Also lots of fun (though a mic and measuring setup is needed to take full advantage).
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Universal Transistor Meter, great tool for matching transistors siliconray Siliconray Online Electronics Store 1 25th November 2011 01:27 AM
Great online speaker calculation tool elac310 Multi-Way 2 4th October 2009 11:46 AM
First time 3-way speaker setup/crossover help. N10 Multi-Way 90 5th March 2009 12:14 PM
Serach for a real powerful Class D with SMPS and PFC and DSP Calvin Class D 9 24th October 2008 07:08 AM
Copyright 1999-2017 diyAudio
