Line Array Tweeter line length?
Old 21st January 2013, 01:05 PM   #41
opc is offline opc  Canada
opc's Avatar
Hi Jim,
Could the same end result (controlled horizontal dispersion) be achieved with a horn loaded design for the array?
I see a few potential issues with the symmetrical array:
1. You triple (at least) the cost of the array
If a 30 driver array is being planned, then you'll be looking at adding an additional 50 drivers or so to make a horizontally symmetrical array.
2. You triple the work involved
Even if you have the baffle CNC cut, it will still take months to wire everything up, mount all the drivers, and seal everything up such that there's access to the driver should one fail. At 4 screws per driver, you're looking at installing 640 screws for a stereo pair!
3. Crossover design will not be trivial
I found it extremely difficult to measure a line array in a domestic setting, which will make the development of a proper crossover very challenging.
4. Physical size is drastically increased
The baffle will now need to be significantly wider, pushing the drivers even closer to the side wall. A minimum 10-12" baffle would be needed to accommodate all the drivers.
With a properly designed horizontal horn, you'd get similar horizontal dispersion control, plus a significant gain in efficiency for minimal extra cost and work. The physical size could still be an issue, but if this is sitting on top of large subwoofers, then the physical size of the horns might fit just fine.
Owen
Old 21st January 2013, 02:58 PM   #42
Jim Griffin is offline Jim Griffin  United States
Default Symmetrical Line Arrays
Owen,
Answers to Questions:
1. "You triple (at least) the cost of the array. If a 30 driver array is being planned, then you'll be looking at adding an additional 50 drivers or so to make a horizontally symmetrical array.
I would say that typically you would use midrange drivers on each side of the tweeter line so it wouldn't triple the cost but it would be a cost increase vs. a typical two line array..
2. "You triple the work involved. Even if you have the baffle CNC cut, it will still take months to wire everything up, mount all the drivers, and seal everything up such that there's access to the driver should one fail. At 4 screws per driver, you're looking at installing 640 screws for a stereo pair!"
Line arrays are a lot of work so you would have more of everything to do.
3. "Crossover design will not be trivial. I found it extremely difficult to measure a line array in a domestic setting, which will make the development of a proper crossover very challenging."
I have found that outdoor measurements work except when the barking dog next door wishes to contribute to the design. Otherwise measurements in a large space--my two car garage qualifies.
4. "Physical size is drastically increased. The baffle will now need to be significantly wider, pushing the drivers even closer to the side wall. A minimum 10-12" baffle would be needed to accommodate all the drivers.
With a properly designed horizontal horn, you'd get similar horizontal dispersion control, plus a significant gain in efficiency for minimal extra cost and work. The physical size could still be an issue, but if this is sitting on top of large subwoofers, then the physical size of the horns might fit just fine."
Size does matter but you weigh size versus benefits. A horn (or these days a waveguide) would help the in-room directivity but at the expense of more a complex configuration. Essentially you have control of the horizontal dispersion with a horn/waveguide.
Another thought is to use a Tom Danley invented Paraline which might reduce the depth of the waveguide as claimed by Yorkville with their work with Tom:
Yorkville Sound: Paraline
Finally a more reasonable symmetrical array for a DIY'er is the Selah Audio array as shown.Click the image to open in full size.
Jim
Old 22nd January 2013, 01:02 AM   #43
mayhem13 is offline mayhem13  United States
Thanx Jim. The Selah array shown is pretty much exactly what i had in mind, just a tad bit shorter at 48" or so and using the Vifa 2" drivers in leu of the ribbons. I haven't been involved in the commercial PA industry for 10 years now but controlled horizontal dispersion was desired in arrays back then and the woofer flanking design stuck with me as the best( but not the cheapest) way of getting that done. One only needs to listen to a horizontal MTM center channel to experience the effect.
Old 22nd January 2013, 05:09 AM   #44
ScottG is offline ScottG  United States
Jim
I've done this with 4" drivers - did not like it at all.
Finally (after a lot of crossover variations - freq. and order under a variety of baffle conditions), a .5 below 300 Hz was barely acceptable.
For lack of a better expression, I hear both lines when it's in the upper mid.s and find the result "confusing". It also seems to "push" imaging forward and reduce the perception of depth. Integration in even a large room really didn't "gel" until I was nearly out the door of the room, and long before then (despite its more directive nature) I was hearing far more "room" than any resulting offset from the added directivity.
Again though, that's just me.
perspective is everything
Old 22nd January 2013, 11:45 AM   #45
Thanx Scott. While your ability to discrern the two lines is surprising, the rest of your obesrvations aren't as many don't care for constant directivity systems which may be the result of the two lines. I admit that such a design might be a bit much for my space.
I've ordered 24 of the two inch and 16 of the three inch for now( PE backorder so i'll have to wait a little while). I'll build two open baffle lines for now and take some measurements and try sub integration first. This should also allow me to integrate the two in a two way to say if there's any advantage to a first order high pass on the smaller drivers.
Old 22nd January 2013, 12:14 PM   #46
opc's Avatar
Very good idea on the prototype work! Although I agree with Scott on this one, we're well into the realm of personal opinion, so it's probably best to build a few variants and see what works best in your space with your own ears.
In general, I feel that the downsides and potential for error with introducing another line and a crossover, purely for the sake of horizontal dispersion control is really not worthwhile in a domestic setting. If this were a PA application and the coverage area requirements were very specific, then it seems to make more sense. In your home though, I think the added complexity and crossover point has too much of a negative impact on sound quality.
Try it either way though, and let us know what you decide!
Owen
Old 22nd January 2013, 03:11 PM   #47
speaker dave is offline speaker dave  United States
speaker dave's Avatar
Just a couple of comments:
Line arrays have no impact on horizontal directivity, which remains that of a single element. Putting side by side lines just adds a horizontal crossover/directivity aspect to the design. The main reason to do it, I would think, would be if you needed the greater bandwidth and power handling that you might pick up. It is definitely an added complication and will somewhat reduce the elegance of a full range array.
One thing to remember is that you pick up huge output at LF with a multielement array. For every doubling of units you get coherent summing and +6dB in level (less so at HF in the nearfield). So if you can find a wide range unit you can use it much lower in frequency than a single element would survive. Certainly full range arrays crossed over to subwoofers are a practical approach.
A lot of the fat roll inverted dome wide range units look very attractive in this application.
David S.
Old 22nd January 2013, 05:59 PM   #48
Like the Aurasound NS3?.......lots of excursion but a rough top end.....would certainly need a tweeter line with those......which I'm not opposed to.
But I think you've uncovered my doubt....that neither the 2" or 3" Vifa's that I've mentioned will get to a sub crossover without significant HD. We'll certainly find out once the drivers I've ordered arrived. Thanx for the feedback Dave. I look fwd to getting further input from you once the proto's are up and running.
Old 22nd January 2013, 09:33 PM   #49
David S.
Yes, any real "benefit" in increased horizontal directivity is over a fairly small bandwidth (..if it's there at all).
Worse, it's typically in an area where:
1. It's disadvantageous (from a psychoacoustic perspective), and
2. Where the tweeter line is often radiating as full omni - making integration that much harder at the crossover (..unless the tweeter line is properly loaded down to those freq.s.. - which is almost unheard of in a domestic speaker).
There are probably also some added problems relating to diffraction with most similar designs as well.
I guess others can hear this for themselves at a show with Legacy Audio speakers (..like their Whisper). They usually pick a large venue for them, so you can move closer to (and further away from) the speakers to hear what it's like. It's not the same as a line array, but it's not hugely different either.
Old 23rd January 2013, 05:50 PM   #50
Your thoughts on OB vs Sealed? With such a high Qt, I think at least aperiodic will be needed to flatten the hump in the lower midbass.
Line Array Tweeter line length?Hide this!Advertise here!
Cheap Tweeter Horn Line Array gmcalabria Multi-Way 1 26th January 2012 05:23 PM
Tweeter placement in line array? Graydon Multi-Way 12 23rd March 2007 01:15 AM
Tweeter line array Klimon Planars & Exotics 11 5th October 2006 09:01 PM
Line array tweeter and sub configuration scott_jcp Multi-Way 17 11th April 2005 05:38 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
Copyright ©1999-2017 diyAudio
