RC Low Pass Filter problem
Guys I need some suggestion regarding a driver viz. almost similar to Eminence Alpha-8A 8" PA Driver 290-401
Hey, is it the same old driver or do you have a new woofer. Is that for bass duty or is that a mid range (lacking some bass). Do you have any measurements from it? Parameters T/S from factory, anything?!
Is not the same having a driver looking similar to one another with out knowing what its electro-acoustic parameters are. A driver like the Eminence Alpha 8 doesn't go deep and is better used as a mid driver or used in surround speakers, if mains add a sub to it. A big enclosure adequate for another driver would give nothing else really under 40/50Hz. :)
