Active Crossover?! what?
Old 16th January 2013, 07:29 PM   #1
oldies is offline oldies
Banned
Default Active Crossover?! what?
I'm planning for a 4-way horn speaker. horn bassbin (midbass) + horn mid-range + horn tweeter and a supwoofer for lower frequencies. I'm going to use active Crossover but I have no idea what to use. sure drivers have different sensitivities and I'm gonna use L-pad to attuanate them to balance the sound.
I want your opinion about active XOvers. I'm pretty a newbie to this issue. thanks alot
Old 16th January 2013, 07:40 PM   #2
R.I.P.
Active speakers don't need and hence don't use L-pads.
rgds, sreten.
Old 16th January 2013, 07:57 PM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
4way active speaker have 4 power amps, one fore each speaker
you control the level of each from the 4way crossover/preamp
most PA power amps are also built with level control at input
Old 16th January 2013, 08:58 PM   #4
adason is offline adason  United States
adason's Avatar
even your speakers are 4 way, it does not necassary mean active crossover has to be 4-way...it can be two way, split the signal for subwoofer and the rest, two amps per side required, and passive crossover for rest
or get a 3-way active crossover, you need three amps per side, and only have mid and tweeter passive crossover, (often just one cap)
if you decide 4-way active, maybe digital crossover is best option, than you (only) need four amps per side, no passive parts between amps and speakers
good luck!
lots of options...
Active Crossover?! what?Hide this!Advertise here!
The Best Active Crossover - Here! Samuel Jayaraj Multi-Way 37 15th June 2018 09:01 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Active crossover MaXiZ Pass Labs 9 22nd November 2003 06:04 PM
Active Crossover soundNERD Chip Amps 5 24th September 2003 01:39 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
