need help to wind Autotransformer (-d) - diyAudio
Old 16th January 2013, 04:54 PM   #1
Banned
Default need help to wind Autotransformer (-d)
Hello world,
some speaker XOvers (like Klipschorn) use Autotransformers to do the -d function to attenuate the voltage steering to any of the drivers. some other simply use L-pad resistors. I want to wind Autotransformer which is able to do -3, -6, -9 and -12db of attenuation. I want information about the the turns number and everything I need to wind it. I'll use 57EI lamination which is common to wind this kind of Autotransformers.
all help is much appreciated
Old 31st January 2013, 10:00 AM   #2
Banned
bump ...
Old 31st January 2013, 11:26 AM   #3
speaker dave's Avatar
Tapped Autotransformers
If you can log into Lansing Heritage there are some threads on it over there, as JBL used them from time to time.
Not too hard to design yourself if you do some experimenting.
Some hints: inductance is proportional to turns squared. Double the turns and quadruple the inductance. Pick a suitable gauge wire and start winding and measuring and you will easily figure out the constant for your core material. L = n sqrd constant.
Taps are just voltage drops in proportion to total winding length. That is, if you need 3 dB step down, that is 70% of voltage or, say, 30 turns from the end on a 100 turn coil. Calculate what you need or use a voltmeter and AC (say, 1 kHz across total coil).
David S
How unsafe is an Autotransformer? Richard Ellis Tubes / Valves 66 9th March 2010 09:34 PM
Question about autotransformer ( 230V to 115V ) Rodeodave Power Supplies 5 4th June 2007 02:11 PM
Toasty autotransformer Craig405 Solid State 21 2nd July 2006 11:03 AM
Autotransformer for 220v in the UK Pickledcreeky Everything Else 7 9th September 2005 06:39 PM
Rewinding an autotransformer Stocker Parts 4 15th October 2004 05:13 AM
Copyright 1999-2017 diyAudio
