Active Crossover roll-off - Page 2 - diyAudio
Old 18th January 2013, 03:20 PM   #11
You can't measure the acoustic offset with a ruler because you don't know the location of the acoustic centers (which usually varies a little with frequency, besides being hard to guess in general).
Old 18th January 2013, 06:18 PM   #12
I'm not an engineer....never built a speaker, never recapped a crossover.... so take my comments with any amount of salt you feel appropriate.
That said, I did once go to the Klipsch factory and with their lead engineer and a handful of other people (some engineers, mechancial and EE as well as other professions) spent some time doing experiments for the sake of us learning.
One was testing steeper slopes to more shallow.
Long story short, in virtually all of the testing we did (not a classic ABX I might add, just an A/B) everyone felt the steeper slopes sounded better/cleaner than the lower order slopes.
There was less overlap of the drivers range so some issues of overlap were minimized.
My take-away from that when I get into current conversations with people about steeper slopes is I THINK it depends a bit on how you listen.
(again, this is just my seat of the pants opinion, no formal education here on the subject matter)
Anyways... my take is, if you tend to listen at lower levels then indeed, a lower order slope might be perfect for you. If instead, you tend to listen at higher/louder levels, then a steeper slope might be better for you.
Old 18th January 2013, 08:51 PM   #13
Default Suggest seeing what Linkwitz says...
I learned a lot about crossovers reading the discussions on linkwitzlabs.com. Sigfried is very knowledgeable about active systems (yes, he is that Linkwitz).
Yes, I've built some of his designs.... Worth a read.
Old 12th February 2013, 03:21 PM   #14
Wouldn't you know it...? I think that site is gone.
Old 12th February 2013, 04:04 PM   #15
There's no 's': Linkwitz Lab - Loudspeaker Design
Old 12th February 2013, 09:29 PM   #16
tvrgeek is offline tvrgeek  United States
Even though the woofer is coated paper, you may have issues with the breakup with only a second order at 2.5. Maybe. I sure would give it a try. Maybe add a notch so you can keep the lower slope.
You mention the crossover portion. Are you dealing with baffle step and edge diffraction in your crossover? Any all-pass to deal with phase and position? Hint, go visit Linkwitz and see what he says about active crossovers. Also Self's new book is pretty extensive.
Using midrange roll-off in crossover Stu Multi-Way 6 28th July 2009 05:22 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Active CrossOver Toast_Master Subwoofers 4 26th April 2006 07:39 AM
Help with active crossover sunil Multi-Way 3 8th March 2004 10:44 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright 1999-2017 diyAudio
