active crossover summing(isolator mod)
Old 16th January 2013, 01:15 PM   #1
botje1 is offline botje1
Default active crossover summing(isolator mod)
Hi!
I want to summing the outputs of an 3-way active crossover.
so that it behaves like an kill eq isolator.
I came across this: Why Not Wye?
resistor summing.. some people say it will cost phasing problems.
whats your view on that ? i dont care about loosing some sound quality.
then i came across this: Rane SAC23/X3000A (3Way Divider)
sadly the guy has absolutely no info about his projects.
its a rane sac23 mod.. witch uses a summing amp (stereo buffer)i guess..
StereoMix Buffer: http://www.meta-design.jp/Photos/Sac23/Sac2326.jpg
so i assume it takes the signals from the capacitors before they go into the original amps ??
anybody familiar with this kind of circuits ? or has an id of what is happening ?
thanks !
active crossover summing(isolator mod)Hide this!Advertise here!
Summing and Lowpass active filter for LM3886, this OP-AMP correct? Boscoe Chip Amps 5 14th November 2010 04:05 PM
Summing Sides, Active Filter hernanstafe Subwoofers 3 16th March 2007 12:32 AM
Power supply for a active summing block. S.C Car Audio 19 14th June 2004 11:56 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 02:29 AM
