Adding Tweeters???
Adding Tweeters???
Old 19th January 2013, 03:41 PM   #11
balerit is offline balerit  South Africa
balerit's Avatar
Those 10" speakers are mid range units. I used to design and build equipment for 1 man bands and used 10" Zomax speakers as midrange units coupled with 15" Zomax speakers and Sammi bullet tweaters using a three-way secord order filters from my hi-fi speaker designs. They were awesome and rattled the foundations.
Old 19th January 2013, 04:41 PM   #12
Inductor is offline Inductor  Portugal
Inductor's Avatar
As balerit said 2 (good PA) mid range drivers can work out after you decide on your design and after you answer what sreten asked you?!
Stereo or mono? Read his question. Also what size/type/application of speaker you r looking for.
They are good for a 3-Way stereo or for a 2-Way in a stereo + sub mode.
Old 19th January 2013, 04:52 PM   #13
R.I.P.
The 5 pin DIN input could be mono or stereo.
You say the speakers are active, one thing certain is its powered.
If the crossover is active, there will be more than one power amplifier.
Two for a mono speaker, and 3 for mono bass, stereo midrange.
For stereo two tweeters are needed, for mono one might be better.
The baffle driver layout would be useful to advise the tweeter placement.
rgds, sreten.
Old 28th January 2013, 09:16 PM   #14
Elroy starr is offline Elroy starr  United Kingdom
rgds, sreten.
Hi, Sorry once again for the late reply. So after waiting almost 10 days for my DIN to phono converter lead, it transpires that the input is infact an XLR 5 pin, so would i be right in assuming that answers the stereo or mono question? Seeing as from what ive read the XLR5 is used for a ''balanced stereo signal''? Ive composed a rough sketch of the speaker cabinet, im afraid its not quite perfectly to scale, sketchup 8 isnt quite as easy to use as i thought, the dimensions are H:920mm W:550mm D460mm. As for the crossovers, everything is contained on a single circuit board and theres a lot of stuff on there, most of it looks completely alien to me, Perhaps if i try and post a few pictures here would that possibly be any help?? Thanks again
Elroy
Old 28th January 2013, 09:46 PM   #15
chris661 is offline chris661  United Kingdom
chris661's Avatar
I think pictures would be very helpful here.
Old 29th January 2013, 11:01 PM   #16
Hope they are of some help....
Old 29th January 2013, 11:14 PM   #17
The photos wouldn't upload, ill try again tomorow
Old 30th January 2013, 08:29 PM   #18
Here Should work this time, hopefully!
Old 30th January 2013, 10:08 PM   #19
Dissi is offline Dissi  Switzerland
Then you have:
1 cabinet
1 woofer
2 midranges
0 tweeters
4 amplifiers
0 crossovers
Does each midrange have its own housing in the box and is there maybe a capacitor connected to them?
Old 30th January 2013, 10:14 PM   #20
R.I.P.
You appear to have :
Stereo bridged "XLR" input, in a very non standard DIN socket.
(Edit : no that is not right, one screened lead is missing. Its quite
possible all the active crossover stuff precedes the DIN input)
4 chips amps, 2 probably for mids, 2 probably bridged for bass.
But if that true the baffle layout doesn't make a lot of sense.
(Edit : Common sense investigation on your part is needed.)
rdgs, sreten.
Adding Tweeters???Hide this!Advertise here!
Need Help Adding Tweeters to Speakers Wikerman Car Audio 17 22nd December 2012 04:34 AM
Adding tweeters, and impedance drop EWorkshop1708 Multi-Way 1 7th August 2011 08:08 PM
adding tweeters to full range speakers. legendaryfrog Full Range 15 22nd November 2006 06:19 PM
Adding a pair of Jensen 302A tweeters to two way speakers singleended40 Multi-Way 2 23rd August 2006 04:58 PM
