what to do with a pair of 5" 'woofers' ?
Maybe a vintage driver (discontinued). :)
the driver is indeed the one posted by Inductor (edited) (thanks!)
thanks for the suggestions guys
GM, where do i start? If you can suggest anything in particular, or even give the name of a style or design, i am willing to read :)
You're welcome!
Learn Hornresp if you don't already know, then use its Loudspeaker Wizard to 'slide' your way into a design. Based on published specs and a 3 ohm series resistance that effectively doubles Qes:
Fo = 78*0.72/2 = 28.08 Hz
Fhm = 78*2/0.72 = 216.67 Hz
Fc = [28.08*216.67]^0.5 = 78 Hz
GM
