High-efficiency, wide-range midrange? - Page 3 - diyAudio
Old 15th January 2013, 03:51 AM   #21
freddi is offline freddi  United States
freddi's Avatar
Audio Nirvana stamped frame Super 8 in a pipe and on-axis - off axis things will drop
Pioneer "BOFU" vs Fostex 206EN on-axis
"BOFU" vs Super 8 on - axis
FE206EN vs Super 8 on-axis
Alpha 6A is a tough and low distortion driver - Art's setup should play loud
Alpha 6 on a conical horn - other trace is an alnico JBL LE5 on Bruce Edgar's rectangular tractrix horn
On and Off axis
On axis
Old 15th January 2013, 07:47 AM   #22
The BG Neo10 planar will cover this range. Run two in parallel and you'll get that kind of efficiency too.
Stick them side by side for the equivalent of a 10" driver, or vertically for better horizontal dispersion.
Old 15th January 2013, 04:48 PM   #23
5th element's Avatar
Originally Posted by tsiros View Post
plenty of 8" drivers do that (fostex, lowther, audionirvana, seas) , not sure if there are other constraints implied here.
Yes, but off axis will be a nightmare.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Using 12" guitar element as high efficiency midrange? Elias Multi-Way 53 30th June 2014 02:23 AM
High efficiency 12 inch midrange - recommendations? hasselbaink Multi-Way 13 8th March 2013 11:23 PM
looking for recommendation for high efficiency midrange for open baffle hum4god Multi-Way 14 14th January 2011 08:04 PM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
high efficiency midrange tsmith1315 Car Audio 15 15th March 2009 11:02 PM
Copyright 1999-2017 diyAudio
