Help IDing Peerless Bass Driver - diyAudio
Old 12th January 2013, 05:24 PM   #1
Default Help IDing Peerless Bass Driver
Perhaps my driver data searching ability is poor, but I've been unable to find a Peerless driver reference sheet on the forum or online that has this part number. Any help or guidance would be appreciated.
Specs:
Basket is stamped steel, rubber surround, plastic / composite cone
8 ohm = specified, DVOM reading = 6.4 ohm
Qc # = 890920
Cat # = 831673
Sticker placed over original driver numbers sticker has these numbers = 2 92-0050
(Possibly a Parts Express inventory number?)
Bar code # 9 316730 000015
Again, thanks for any deciphering help. -- Wornears
Old 12th January 2013, 05:45 PM   #2
Lifelong Learner
jordheis's Avatar
Pictures, dimensions, and where you got it would be helpful to know.
I'm a Groove Puppy
Striving to remove some ignorance every day (always starting with my own)
Old 13th January 2013, 04:48 PM   #3
Default Peerless Mystery Driver
Measurements:
Basket edge-to-edge = 8-3/4-in. (22 cm)
Basket center-of-mounting hole to center-of-mounting hole = 8-5/16-in. (21 cm)
Magnet diameter = 4-in. (10.2 cm)
Magnet depth / height = 1-in. (2.5 cm)
Had to lift up the sticker (# 2 92-0050) to read the original sticker for specs = disfiguring original
Old 13th January 2013, 05:33 PM   #4
diyAudio Member RIP
Hi.
Probably an OEM driver, where are they from ?
rgds, sreten.
Old 13th January 2013, 06:43 PM   #5
Speakerholic
Cal Weldon's Avatar
I'm with sreten. It's an old model from the CC line, but it doesn't show up in any literature I could find so it may have been custom made for a speaker manufacturer.
planet10 needs your help:
Let's help Ruth and Dave
Old 13th January 2013, 06:55 PM   #6
Default Where is the Peerless Mystery Driver From?
Source = swapped audio parts gear with a friend. He didn't know the origin. I appreciate your help.
Old 14th January 2013, 06:27 PM   #7
mjf is offline mjf  Austria
hello.
searched in my old speaker catalogs..........1995
iirc the peerless pt - design line had a foam surruond -
and the cc- line a rubber s.
Old 14th January 2013, 06:49 PM   #8
found more.......... a catalog from 1998
Old 15th January 2013, 04:23 PM   #9
mjf - Wow. And I thought I kept / hoarded older info! Thanks a lot for posting up these catalog pages. They have all the infomation I need. I appreciate your taking time to research and post them.
Wornears
For sale: Peerless SLS 830667 8 inch Mid Bass driver cirrus18 Swap Meet 3 21st May 2012 10:48 AM
Peerless bass - HDS, CSX, SLS Jennice Multi-Way 23 3rd February 2005 09:29 AM
Peerless woofers - bass shy? Mos Fetish Multi-Way 52 12th August 2003 01:57 AM
Copyright 1999-2017 diyAudio
