New to DIY, 1st Project & Need help with Speaker Selection - diyAudio
Old 12th January 2013, 01:11 PM   #1
KMoeD is offline KMoeD  United States
Default New to DIY, 1st Project & Need help with Speaker Selection
Need to start by saying that i am definitely not all that knowledgeable when it comes to all the electro/crossover circuitry etc. with speaker systems
Current set-up is simple; Kef IQ1 Bookshelf speakers and a IQ9C Center Channel - And, Im in the process of building a enclosure for my Eminence LAB12 Subwoofer (sealed) to add some punch for movies etc.
I've wanted some better speakers primarily for music; like everything from classic rock to classical - i like to hear the individual instruments so getting it right, well....i need HELP!
I've researched various sites for both design and components; need advice on both my speaker selection and crossover/circuitry....Again, Thanks in Advance for any help offered!
Woofer: Aurum Cantus AC300/75C2C 12" - Sealed Enclosure
Mids: Tang Band W5-704D 5-1/4" Woofer - 2 per speaker - open Baffle in a (MTM) configuration
Tweeter: Dayton Audio PT2C-8 Planar
No clue on Crossover's yet - haven't gotten that far
And, hoping the Eminence LAB12 will handle the really low end of things - this will be paired with a Yung 300W (non-boost model) plate amp from PE
I'm still in the planning process - Thoughts & Suggestions are appreciated
Inspired by this design - except single front firing woofer vs dual
http://gainphile.blogspot.com/2012/03/s19-4-way-dipole-radiator.html
Old 12th January 2013, 02:00 PM   #2
Inductor's Avatar
I've researched various sites for both design and components; ....Again, Thanks in Advance for any help offered!
Tweeter: Dayton Audio PT2C-8 Planar ...
And, hoping the Eminence LAB12 will handle the really low end of things - this will be paired with a Yung 300W (non-boost model) plate amp from PEI'm still in the planning process - Thoughts & Suggestions are appreciated
easy.
need advice on both my speaker selection and crossover/circuitry....No clue on Crossover's yet - haven't gotten that far
more difficult.
Old 12th January 2013, 02:34 PM   #3
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
Do you already have these speakers? If not, you would probably be better off going with a current design. The Parts Express website has a lot of designs by very knowledgeable people. An internet search will also provide a lot of designs.
If you already have those designs, maybe someone here can help you with a crossover. Again, the Parts Express forum is almost exclusively about DIY speakers, so I'm sure you could get a lot of help there too.
Just in case you were tempted to go with an off the shelf crossover, I'd recommend not doing so. A crossover needs to be designed for a particular speaker. Each speaker has its own impedance signature and needs filtered/notched in some areas that others don't. Although an off the shelf crossover might sound OK, one designed for the speakers will sound better. It looks as though the speakers you listed are very nice speakers, so you should do them the justice they deserve with a crossover designed for them.
Just my 2 cents....
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Bjorn's PS95 TABAQs
Old 12th January 2013, 02:49 PM   #4
Thanks Mike, i will check over on the PE forum for additional information - aside from speaker selection (ensuring components match), I'll most likely plan to have the crossovers built vs DIY...."man's gotta know his limitations" :-) Clint Eastwood. That said, any suggestions on components is definately welcome. And, no i have not purshased the speakers yet but plan to get started soon.
Old 12th January 2013, 03:33 PM   #5
Inductor's Avatar
Yes, and as Mike said if the choice of the drivers is yours it looks promising.
Aurum Cantus AC300/75C2C 12" Woofer
Dayton Audio PT2C-8 Planar Tweeter
Tang Band W5-704D 5-1/4" Woofer-- has anybody used this?
Edit: If you can have two speakers ~bigger than 100L "Aurum Cantus AC300/75C2C" you don't need sub (F3=<30Hz).
Two speakers@3 meters = 108.9 dB.
Old 12th January 2013, 03:46 PM   #6
Thanks! And, noticed your from Portugal...i was stationed in the Azores for 4yrs - loved it - Goooo Benifica, your probably a Sporting fan, LOL
Figo...one of best football'ers ever
Old 12th January 2013, 03:53 PM   #7
I have used the W5-704D in a budget two way. It does well as a woofer for its price. As a dedicated mid I can only imagine it will do very well. However, I imagine there might be better mids to go with the woofer and tweeter you've chosen. The W5-704D is slightly veiled to me. It's easy on the ears, but the mids are the real "money-maker" in a speaker. IMO. I have a set of speakers designed by Paul Carmody, from the Parts-Express forum that use a W4-1337 Tang Band W4-1337SD 4" Titanium Driver 264-848. It makes an extremely nice mid. I don't think it would need a lot of crossover work either. And if I'm not mistaken the lower sensitivity of the W4-1337 would help with any BSC issues.
Mike
Old 12th January 2013, 04:29 PM   #8
diyAudio Member RIP
The LAB12 likes a 100L vented box tuned to 20Hz,
see : Monolith+ DF+ and FF+
You don't need 12" woofers to go with it.
This sealed is a good idea, all the x/o work is done :
https://sites.google.com/site/undefi...diy-sunflowers
(Though TBH the 23Hz vented doesn't need a subwoofer.)
Certainly the midrange distortion will be a cut above the
W5, which is a very nice driver, used OB MTM is this :
https://sites.google.com/site/undefinition/diy-aethers
rgds, sreten.
Old 13th January 2013, 12:41 AM   #9
Inductor's Avatar
........ Jeeeeez !!! 4 years, hope you were not chemtrailing me all this time...
1st DIY project ocak Multi-Way 2 22nd June 2009 02:48 AM
DIY: SI T Amp Boombox, FR Speaker Selection dellaseppes Full Range 35 20th February 2007 04:35 AM
Building my Charlize, 1st DIY project..... kenscott30 Class D 6 3rd January 2006 02:32 PM
My 1st DIY project pk386 Chip Amps 12 7th May 2004 06:48 PM
Pics - 1st DIY Speaker Project omni1 Multi-Way 1 19th July 2003 01:59 PM
Copyright 1999-2017 diyAudio
