Does anyone here have any experience with a bass-reflex system that uses a horn at the outer end of the port? Particularly retrofitting a horn to an existing system.
Maybe even a horn on *both* ends of the port. That'd be interesting. |
#2 |
diyAudio Moderator Emeritus
Hi Graham,
That imagination of yours never takes a rest does it? Using a horn for a port would be similar to using a flared port. The horn would be too small to have any real effect at the operating frequencies of the port.
Rodd Yamashita |
#3 |
Banned
No port with horn, but not far. My Altec A7 like Loudspeakers as far as i understand are portet boxes below ca. 150Hz. These speakers are not really famous for bass response. Measurement of the box standing free in room shows something like bass from 60Hz up. Placed in the rooms corner (= horn) i have bass form about 40Hz upwards. So i think about building a room with 2 suitable corners to avoid subwoofers.
http://home.tu-clausthal.de/~tpa/VotT/IMAGE0056.JPG |
#4 | |
What I really want to do is put a big funnel on the port hole of my sub to get super-duper efficiency over a necessarily limited range of frequencies. Or should I just shove it over the front of the driver instead? Or have both the driver *and* the port hole talking into the small end of the horn? /Circlotron - making horn experts groan for sure. |
#5 | |
I would also initally set the port tuning frequency a bit higher than you would in a standard vented box, also from my experience in car audio, assuming you will be making a pretty large horn. |
#6 | |
Cheers |
#7 |
http://www.decware.com/wicked1.htm
1m horns are not bass useful. not a horn but a waveguide how would you calculate it? youd have to use horn software as a p ort cant be expanding like that and still be calculated. Like a giant vero-vent the chambers are allowed to breath through the carpeting altering the impedance curve on the fly to enhance efficiency, and more importantly create a sympathetic diaphragm out of your floor!
#8 | |
isn't that what a rear loaded horn speaker does (the front radiates sound directly at the user and the rear picks up the efficiency [usually of the lower frequencies] by channelling the rear wave through a horn guide)?
"Any fool can know. The point is to understand" - Albert Einstein |
#9 |
A port in a BR type system operates on a different principle than a horn. A horn is an acoustic impedance transformer. The horn serves to increase the acoustic impedance on the compression driver so it can more effectively deliver its power to the room. A port holds a mass of air that resonates when excited at a particular frequency (tuning frequency) against the “spring” of the air in the box.
I’m implying that this idea won’t work, just that there are two different principles at work here.
Rodd Yamashita |
#10 |
Its interesting how this morning I was thinking the exact same thing.
I'd suspect someone good with double BR boxes (MJK has a worksheet for them) could help on this one.
Time is the best teacher; unfortunately, it kills all its students |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| Front loaded and back loaded horn | DrWoofer.com | Subwoofers | 0 | 3rd August 2007 06:55 PM |
| Rear Loaded Horn | David R. Carlso | Full Range | 3 | 9th January 2006 10:04 PM |
| Would this work - Karlson + slot-loaded port | DeonC | Subwoofers | 27 | 26th September 2005 07:11 AM |
| Need help with horn-loaded sub | slicemaster101 | Multi-Way | 26 | 17th September 2002 01:09 PM |
| Page generated in 0.10057 seconds (81.25% PHP - 18.75% MySQL) with 11 queries |
