Can you help me find a speaker design that uses the SEAS drivers in tread
Old 11th January 2013, 02:09 AM   #1
sibbeli is offline sibbeli  Sweden
Default Can you help me find a speaker design that uses the SEAS drivers in tread
Hi!
I quickly ditched my idea for a 2,5way speaker as they are more trouble to build.
So, now i want to build a 3-way.
I would really like to use just seas drivers because their drivers are the cheapest of the high end european made drivers, and their performance is almost on par with scan speaks best drivers.
I want to use theese drivers preferably:
SEAS 27TBFCG
A tweet with lower dist than most of seas prestige tweeters
SEAS CA15RLY
Often used midrange driver with good distortion too
SEAS CA22RNX
Another driver with low distortion
SEAS 27TBFCG
SEAS CA15RLY
SEAS CA22RNX
And i would really really like to copy an already existing desicn as I`m not totally confident in crossover designing..
So, please folks, cant you peaple link in all seas 3-way systems you know of?
There has to be someone that has built a tower with exactly the same drivers..
I am Norwegian born and Seas is for something really apecial, they are close to my heart.
And the quality of the drivers are simply exellent!
I want simple clean towers, with as small baffle as possible and they can be as tall as 50"
IF you find a design using peerless or scan speaks better priced drivers, link them too aswell
Thanks in advance, hope you guys help me find that tower i am going to build
So my friends,
Old 11th January 2013, 02:56 AM   #2
Please help me find designs that also uses other tweeters.
Please
Old 11th January 2013, 03:08 AM   #3
PeteMcK is offline PeteMcK
DIY Loudspeakers constructions
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 11th January 2013, 03:17 AM   #4
i have gone trou troels site and there arent any towers with my rdivers there
He has designss with my drivers but they are wide classical boxes so, i cant change the width or height without totally destroy his xo...
ASTASIA here on diy uses a different tweet, but it seems that it may not be so god.. i dont know, very little respnce in his tread
Old 11th January 2013, 03:21 AM   #5
Humble Homemade Hifi
Old 11th January 2013, 05:29 AM   #6
tf1216 is offline tf1216  United States
This project satisfies some of your criteria.
3-Way Classic
Old 11th January 2013, 05:44 AM   #7
barossi is offline barossi  Germany
Poor Man'
KR Hauke
Old 11th January 2013, 09:09 AM   #8
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
The PMS is praised for it's good sound in living rooms, see horizontal dispersion, at Troel's page. 27TFFC and 27TBFCG can be swapped without modifications to xo
AINOgradient speaker project
Old 11th January 2013, 10:58 AM   #9
Dissi is offline Dissi  Switzerland
3-Way Classic
It's no problem to make a tower version of the 3-Way Classic. Simply increase the height to 1m and shorten the vent to 80 mm. The woofer works well in volumes up to 75 litres. No crossover modification required.
Old 11th January 2013, 08:55 PM   #10
re:"i cant change the width or height without totally destroy his xo..." - only 2 components need to be changed.
The drivers you have chosen are easy to crossover, If you want to learn a bit, have a go.... use straightforward LR 2nd order xovers & you won't have a problem (Troels makes his a bit complicated IMO)
Can you help me find a speaker design that uses the SEAS drivers in treadHide this!Advertise here!
3-way - Tower Speaker Project with Seas Drivers WaVeInFoRm Multi-Way 139 20th December 2015 10:43 PM
FS Speaker Drivers Eton & SEAS- midrange markmelheim Swap Meet 1 11th June 2012 04:56 PM
Curved speaker design using B&W DM604 s3 drivers skumar321 Multi-Way 5 6th March 2012 01:25 PM
help with crossover design for some 2way focal+seas speaker perica Multi-Way 11 14th March 2011 03:45 PM
Just an ebay find, couldn't find info on the Ramsa drivers azneinstein Full Range 1 22nd November 2010 09:11 PM
