Hi everyone,
Last week I picked up busted 332's. I heard so many good reviews about these. Unfortunately one tweeter is not working and there is a burned resistor in crossover. I'm planning to make full maintenance including cabinets. I'm searching for info since four days. Couldn't found any reliable information regarding crossover schematics. Is anyone have any schematic for 332's? Also I want to try repairing hf2001 tweeter which is already down. So nothing to lose if I cannot find a way. Another thing is I have a hard time to remove drivers.Looks like drivers doesn't glued, tight fitted, but i cannot remove them. I was able to remove two tweeters and one woofer. But I don't want to force the baffle. Any recommendation about this? Any information will be appreciated. Still desperately searching for xover schematic.... ![]() Regards. |
#2 |
In another forum (AudioKarma.org) they say SEAS H0737 it's a good tweeter substitute, having in mind that's a smaller faceplate.
Substitute both resistors in both crossovers, look at the value on the new one. |
#3 | |
Another question; As I see this 332's uses paper capacitors. Do I have to replace these with pp caps. If so, it will cost a lot for me |
#4 |
Ok, got reply from dealer about Seas H0737 replacement;
"The Seas H0737 is the recommended replacement for the HF2000 and the HF2001. The sensitivity etc. is the same so there should be no problem with the crossover." As far as I understand, I don't need to experiment with the crossover? |
#5 |
Here's damaged crossover with blown resistor. Btw, I have to find a way to remove drivers without damaging cabinet...
#6 | |
#7 | |
There is no subtle way of removing the woofer. If you can reach inside the cabinet with sufficient leverage, give the back of the woofer magnet a good smack. If you can't get inside, then use something like a snap ring pliers with a substantial hook at the end that you can slip into the mounting bolt hole and give it a strong pull. No doubt you may get a bit of separation of the particle board they probably used, but it won't be catastrophic. |
#8 | |
Cabinet design is somewhat strange to me. Mid drivers have their own closed boxes inside the cabinet. There is no way in. I have to pull them straight without damage. To do this, I have to find something.. |
#9 |
Update;
Succeeded to remove all drivers without any issue. Cabinets in sanding phase right now. Unfortunately other crossover also in bad shape with replaced anonymous electrolytics. Hopefully I found a pair of clean&working 332 crossovers. In the meantime, does anyone have ditton 332 crossover schematics and wiring diagram? sb. |
#10 |
I think you can work out these values with a bit of help and detective work. A diiton 332 crossover pictured here:
New SEAS drivers in Ditton 332 Cabinets That's 4 of the cap values I can see straight off. C4 is 12uF NP. Small C7 might be 1.5uF NP, not sure. You'll need a good mutimeter with an inductance scale to measure your coils. Keep track of wiring polarity too. Here's a typical 3-way for comparison: 3-Way Classic This whole thing might be best rebuilt on new PCBs: http://www.wilmslow-audio.co.uk/crossover-pcb-452-p.asp I think I could guess some values if you can draw up the schematic. Celestion did reuse a lot of circuits. Usually a 4th order bass and third order tweeter, but let's see. This is not an easy restore, but if you are methodical and make notes it can be done, I reckon.
Good Night, and Good Luck. Best regards from Steve in Portsmouth, UK. |
| celestion ditton 332 crossover | goalhanger | Multi-Way | 17 | 5th September 2011 02:44 PM |
| New SEAS drivers in Ditton 332 Cabinets | goalhanger | Multi-Way | 11 | 8th July 2011 02:03 PM |
| Celestion Ditton 662 crossover specs needed | SatinMill | Multi-Way | 6 | 19th October 2010 09:28 PM |
| Celestion Ditton 25 Crossover Schematic | lardossen | Multi-Way | 2 | 7th March 2009 07:23 PM |
| Celestion Ditton 15 or 15XR Crossover | Bennyboyph | Multi-Way | 7 | 4th January 2006 08:26 PM |
