Sound changed after speaker restoration
Old 9th January 2013, 08:11 AM   #1
Exrabies is offline Exrabies  Netherlands
Exrabies's Avatar
Default Sound changed after speaker restoration
Hi all,
My Emotion speakers (image nicked from the interwebs, but mines are identical) just got a new paint job after almost 20 years of children's abuse . I dismantled them beforehand. After putting 'em back together left and right speaker sound rather different. Left is (overly) bright but open. Right is laid back but (a bit) muffled. Used a TEAC amp with low, mid and high controls to check differences, and it's mainly the mids that differ.
Attached pictures show frequency analysis (mono-channel, 1m from floor; 1m from speaker; 30 sec. Norah Jones song). Can anyone give a hint what could have gone wrong. My suspicion is that I put back the damping material differently.
Thanx,
Adam.
Old 9th January 2013, 08:53 AM   #2
phase_accurate is offline phase_accurate
It is hard to tell differences by using a recording as a reference (they do differ in the contenet of the channels after all).
The biggest difference I see is in the mid-high crossover area. Are you sure that you reconnected all drivers with correct polarity ?
Charles
P.S. : This is the wrong sub-forum BTW
Old 9th January 2013, 09:05 AM   #3
Exrabies's Avatar
Charles,
Thanx for the reply.
I picked the 'Loudspeakers/Full range' forum. Is that not the correct one?
The charts are both from the left channel of the CD, and fed into both speakers (one after the other of course). I will check polarity as per your suggestion. A real pain to dismantle 'em again however.
Adam.
Old 9th January 2013, 09:14 AM   #4
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I've moved to multiway
Pink noise (or a proper mls or sweep) would be best. Also you should really move the speakers so that both measurements are with the speaker and mic in exactly the same spot.
If you get a program like audacity you should be able to create a pink noise file of arbitrary length and burn it to a CD if hooking the computer up is not an option
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th January 2013, 09:33 AM   #5
Exrabies's Avatar
Hi Tony,
Gotta love this forum (and its members)...
I used Audacity to produce the Freq. picts. Will try some 'real' measurements (square, sine, sweep, pink noise) anyway before taking the speakers apart.
The reason I asked the forum for input is that I HEAR something is wrong. Measurements probably only aid in pinpointing the culprit. Well actually I hoped someone would say "without a doubt it's ... that's causing this" ;-).
Regs,
Adam.
Old 9th January 2013, 10:53 AM   #6
just another
wintermute's Avatar
If you have indeed wired up one of the drivers out of phase, a proper frequency sweep or pink noise test should show it up pretty clearly you should see quite a suckout around one of the crossover points! My first ever acoustic measurement (which was done with a very poor quality computer mic) made it very clear I had my mid's wired the wrong way around!!
Tony.
Some of my photos
Old 9th January 2013, 11:19 AM   #7
diyAudio Member RIP
As long as you can hear difference swapping of drivers and the like
should pinpoint the problem. Maybe tired capacitors in the x/o.
rgds, sreten.
Sound changed after speaker restorationHide this!Advertise here!
Nextel suede paint speaker finish restoration limono Multi-Way 2 30th November 2012 06:35 PM
Someone Has Themselves a Challenging Speaker Restoration Project! DreadPirate Multi-Way 1 12th July 2010 05:25 PM
Opamps changed => metallic sound roibm Solid State 2 22nd March 2004 11:17 AM
I wonder if (Bl) is changed. haggy Multi-Way 0 7th April 2003 09:55 AM
How would you like DIYaudio.com changed? Jason Everything Else 21 27th August 2001 09:07 AM
Copyright ©1999-2017 diyAudio
