Help identifying / sourcing a part please
Hi all.
The below part has gone on one of my crossovers (from dBTechnologies Opera 302 Lyrics - passive speakers).
I think it's a resistor but not absolutely sure! The tweeter isn't working anyway and I've traced it to this part.
The good one measures 6 Ohms. There are no markings of any sort on the item in question.
Many thanks in advance...
A
Just another Moderator
Joined 2003
They are invaluable if you have parties where the guests invariably crank up the amp to far ;) Saves your tweeters from blowing. Wish I'd known about them when I was lugging my speakers to parties on a regular basis :rolleyes:
follow moondogs link and have a look at various ones, bearing in mind the power rating and nominal impedance of your tweeters. eg if you have an 8 ohm tweeter rated at 10W look for a polyswitch that will trip out around that value.
Check if the device is in series with the tweeter, if it is then the chances it is a polyswitch increase a lot :)
Tony.
Thanks for the input... As the speakers are in a dance studio and people regularly plug / unplug iPods without turning the gain on the mixer down & crank up the volume I think it best to leave the protection in place...
I'll have a look at the speaker rating then try to find something suitable...
Thanks again
A
