Old 10th February 2013, 03:23 AM   #31
Default Pre-prime prep complete
Ready for primer, driver holes taped off, in the paint booth. Yea!!
Old 10th February 2013, 11:56 AM   #32
JonasKarud's Avatar
Excellent!
For even better sonic results, try to mount the coils so that their
induction axes point in different directions.
Old 13th February 2013, 04:38 AM   #33
Originally Posted by JonasKarud View Post
Excellent!
JonasKarud, thanks for commenting. It was all I could do to get these in the way I did, due to space. I only had about 2 1/2" depth to work with and some of the coils are larger than that on their side. I was able to organize them, as in the pic, with 3 1/2" between them. Before I fixed them to the board I sent a pic to Troels and he said he thought the layout looked fine. I know it would have been a safer bet to organize in different directions as you said.
We will see soon, put the first 2 coats of primer on today;
Let the sanding begin!
Old 20th February 2013, 06:55 AM   #34
Default Almost ready for color
Nice to have a 3 day weekend. I was able to spray the last 2 coats of primer Saturday. Monday morning spent sanding it all over again and filling the small imperfections with some spot putty.
After lunch I wiped them down with a damp cloth and rolled them into the booth. I sprayed them first with a medium wet coat of DTM epoxy primer/sealer, then two medium wet coats of black base coat, then two medium wet coats of Chroma Clear.
Here is a pic of one final sanded and one with the spot putty.
K&K Audio modified Dynaco ST-70 Amp, Dynaco PAS-2, Emotiva XDA-2 DAC, Pioneer Elite BDP-62FD Player, Sansui SR-838 turntable, Ekta Grande speakers
Old 20th February 2013, 07:24 AM   #35
Default Color on
I pulled them out of the booth this afternoon and started the first round of color sanding. Sanding as little as possible with 1200 grit and pad to make the "orange peel" disappear. I was pretty proud of them at this point. With as much sanding and buffing ahead of me I almost talked myself into taking them home, they looked that good. But, sticking to plan, finish the color sanding, then 2 more coats of clear, then another round of color sanding, then the polishing.
Here is the first one almost complete with color sanding and the one on the right is right out of the booth;
Old 6th March 2013, 04:41 AM   #36
Default Cabinets complete, wiring
I used ASA Kable Silver Plated 12 Gauge Speaker Wire for the internal runs, zip tied to each brace to keep from banging around
Old 6th March 2013, 04:47 AM   #37
Default Crossover installed
I made a recess in the bottom of each cabinet to house the crossover separate from the cabinet internal area for easy access.
Old 6th March 2013, 04:50 AM   #38
Default Installing drivers
First set of drivers going in
Old 6th March 2013, 04:58 AM   #39
Default Trying them out at the shop before I took them home today
I was so excited!! Powered right up and sounded great, even in the large open shop. I was really shocked at the amount of base and cleaness of the treble in the worst type of environment. Source audio was my iPhone through the PAS 2 (all tubes4hifi upgrades), I still have to place the Acoustilux, install the rest of the screws and re-install my signature/logo on the right speaker
Old 6th March 2013, 05:06 AM   #40
Default Finally home!
This project started forming in my mind the end of December and now nearly complete and home the first of March. I can't believe how much sanding and polishing these took!
I used a 2 step process, all DuPont Choma products. Each cabinet has 4 coats of clear. Wet sanded with 1200 grit after the first 2, then back in the booth for the next 2. After the second set of 1200 grit wet sanding, then 2000 grit. Then the polishing. I used 3m's Perfect-It 3 step system. Each step uses a different compound with matching buffer wheel. I thought I would never finish!
FYI, each cabinet has about a third of a gallon of clear.
Ekta Grande baffle changes dublin78 Multi-Way 6 11th October 2011 03:40 PM
B&W683 or EKTA Grande? junjuvava Multi-Way 4 13th March 2011 09:35 PM
Is nxV200 and Ekta Grande junjuvava Solid State 0 2nd March 2011 05:33 PM
New Ekta Grande/ZRT varation dotvibe Multi-Way 18 24th July 2010 05:36 AM
Ekta Grande cabinet size? dublin78 Multi-Way 1 22nd July 2010 04:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
